12-03-2013, 09:27 PM | #26 |
Vintage 4x4s
Re: Looking for a cummins donor vehicle for 2500hd
sounds like he's going to have the trans out tomorrow so I can pick up the truck after work. Weather is sloppy now and they're salting the roads... Man I don't want to get salt on my trailer or 2500HD but I guess one trip won't hurt it too bad. Gotta hit the car wash afterwards I guess.
Starting to learn more about the conversions, sounds like I will want to get a NV4500 bellhousing, use a 13" clutch, and then do an adapter plate on the back of the bellhousing to connect the SM465. And use a 1.5" input shaft out of a medium duty chevy.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
12-05-2013, 08:11 PM | #27 |
6>8 Plugless........
I would just use a NV4500 and toss the SM465. NV4500 has overdrive and you can use a NP205 29 spline from a first gen manual dodge and eliminate the hodge podge of 2 bell housing adaptive deals. Plus, if your truck has low gears, you'll hate that cummins swap with no OD.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-05-2013, 10:38 PM | #28 | |
Vintage 4x4s
12-05-2013, 11:06 PM | #29 |
Vintage 4x4s
How far back would I have to slide the driveline to fit the cummins under the hood of the K20?
With the storm we had here, it looks like Sat is the day to retrieve it from the urban jungle in the heart of Minneapolis.
12-08-2013, 02:45 PM | #30 |
Vintage 4x4s
got it home, took some effort though. It was a tight fit getting it out of the tight alley/backyard, and inch was froze up at first and so was trailer jack but I managed and all went well. At least the roads weren't sloppy, just some hard frozen pack.
Now to figure out what the heck it will take to get the SM 465 connected to it. THink I'll park it out in the field until spring, then think about yanking the engine and front axle out and scrapping the rest. Speaking of front axle, according to the BOM number stamped in the axle tube, its a D61 with 3.54 gears. I have a D60 rear 3.54 sitting here so I'm starting to think that may be a good solution. The D61 may actually work out very well for me with that gear ratio. I was afraid it might be a 3.07 which most D61's seem to be. As long as the joint and brakes are the same as a d60, I'm going to be in good shape.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 12-08-2013 at 02:57 PM. |
12-08-2013, 02:55 PM | #31 |
Vintage 4x4s
More pics. Of course, it came with the obligatory junk tv in the back. I could have *****ed about that but I still got a good deal so whatever. It has a good 7500 lb hitch on the back I didn't see before and AC, which may be nice in the truck its going into.
Wonder if there is any value in the narrow dually rear..
12-09-2013, 04:39 PM | #32 |
Jud, that truck looks to be in pretty good shape for a first gen dodge. I also found out that according to Quad4x4 they did offer 3.54's in some D61's. I never heard this before or knew that before. The info is about half way down the page.
http://www.quad4x4.com/DodgeDana60front1975-1993.html
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 12-09-2013 at 04:59 PM. |
12-09-2013, 11:58 PM | #33 |
Yep I agree. That dodge is a diamond up here in ontario. Most of ours you can stick your fingers up inside the roof pillars from the inside . Thats if the floors lasted long enuf for the roof to rot next. I didnt know what a D61 was till the other day . Everyone is learning here ! You will be able to use lots of stuff from that truck for sure .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
12-10-2013, 12:13 AM | #34 |
Vintage 4x4s
Its not as nice as it looks but maybe I can sell some of the body parts to some 1st gen fan around here.
It does have some other parts I can use, the two front tires, hyd clutch pedal, and wheels and the hitch. Its also got a decent mid 90's chevy bumper I may be able to sell. Too bad the Reading box is shot. (rusted through in all compartments). Any thoughts on the D70/D80 rear? Would the 3.54 R&P be worth pulling? Suppose I should check for posi.
12-10-2013, 08:06 AM | #35 |
If you are scrapping the truck then you should just pull the whole thing . I dont think its a dually rear tho , you dont have the dually front hubs . Unless sumone has swiched it . I could measure my d70 dodge rerar that is in my 56 if you like .
12-10-2013, 04:14 PM | #36 |
If you're going SRW with your chevy use the D70 as they aren't as wide as an 80. SRW to SRW. Just look how far out my tires are on my Longhorn, that is a D80 SRW in the back of it.
12-11-2013, 11:02 AM | #37 |
Vintage 4x4s
the inside of brake drum to brake drum distance is only about 4', so it must be a dually rear that was swapped in when the box was put on. the rear springs are a stack of more than 12 each also!
I bet there are more of these dana 61.s out there in trucks who's owners think they have a 60. still wonder why it would have a 61 since a 60 was available with 3.54. perhhaps they had more inventory of 61 to use up? do you guys think a d60 3.54 rear with the stock Dana Powr-Lok would hold up well behind this 1st gen cummins?
12-11-2013, 04:59 PM | #38 | |
12-14-2013, 11:26 AM | #39 | |
Vintage 4x4s
Now if there were a way to make the HO52 axles fit in the Dana The eatons look indestructible! Or get 3.54's to fit in a HO52 but I';ve never heard of that.
12-14-2013, 12:26 PM | #40 |
I would go with a heavier rear. the 60 is just smaller all around. brakes, r&p, shafts... being in farm truck country i cant think it would be terribly difficult to chase down a 14 bolt or a d70/80. i cant think of one truck that used a 60 behind a real diesel in stock form(excluding the NA6.2 and 1/2ton 6.5 trucks). but if you know the limits and dont push at them it would probably not really give you any issue just putting around. put a lot of torque through it with a load though and you will probably see some busted metal. or at least worn out parts quicker.
im going to recommend that you go ahead and swap the front pinion yoke to a 1350. any dana 60 yoke from a similar year i.e. a chevy ford or dodge dana 60 will work on the 61. i have replaced a few of those on trucks with owners that just wanted to be done replacing u joints. you will likely have make or find replacement drivelines anyhow so the yoke only adds a little extra cost. you can look for a 2nd gen dodge front shaft at the JY as they have the same saginaw style flange at the t-case as the dodge 205s and a 1350 cv joint as well as a 1350 yoke the other end. |
