03-17-2013, 12:08 AM | #26 |
Tot Roddin'
Re: 'Rose' interior pics
Beautiful!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-17-2013, 12:31 AM | #27 |
What paint code and color combo is that? I like it a lot - just wondering if that is a GMC specific color or what....
03-17-2013, 02:18 AM | #28 |
Clean truck. I just had a few questions. Was it a problem to fit the 72 door panels on it and what do you think of using the A6 compressor. Thanks
Posted via Mobile Device |
03-18-2013, 09:28 AM | #29 | |
Florida Edition
The color is a factory GM color...from 1955 (one year only), Seamist Green. I believe the paint code number back then was 586, you might want to double check that though. I went with single stage, not much of a clear coat fan on non-exotic colors.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
03-18-2013, 09:38 AM | #30 | |
Florida Edition
The 72 door panels are not a problem, just need 72 regulators due to the longer stems. I posted the process on here a long while back, I'll see if I can find you a link when I get a break here at work. I went with the stock style compressor to keep the stock look under the hood, it does leak a very small bit of oil from the front seal when it's on like they all did but it cools the cab exellently.
03-18-2013, 09:44 AM | #31 |
Very nice work
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
