Old 03-16-2013, 01:53 PM   #26
Super73
Super73's Avatar
Re: LQ9 power
Pass on the 6l80 for me. That first gear would do nothing for me but blow tires off. I would have to start in 2nd..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-16-2013, 05:36 PM   #27
thotfulspot
Re: LQ9 power
Originally Posted by Jon01 View Post
Same here. I had a fresh 4L60E and sold it to put a used 4L80E in.
I would not trust a stock 6L80E behind even a mildly built LQx.
That being said, an easy recipe for a 500+fwhp LQ9 is:
799 heads, MS3 cam, F-body accy's, LS6/FAST intake and LT header of your choice.
What motor are the 799 heads from? I assume that is the casting number. I was planning on some new L92 heads mildly CNC ported and a new LS3 intake from GMPP. Does the FAST intake come with everything like injectors and such. The LS3 from GMPP comes ready to bolt on and run. I'm also not familiar with the MS3 cam. Where does that come from? Am I annoying you yet.
I was going to use the truck accessories with some aftermarket brackets instead of replacing everything. Billet Specialties, Dirty Dingo, or some other company. I'm. Not building a show truck, but I would like to use something that looks decent.
thotfulspot is offline   Reply With Quote
Old 03-16-2013, 05:39 PM   #28
thotfulspot
Re: LQ9 power
You're built up a little more than I plan too. First gear will be nice when towing. I'll just have to keep my foot out of it when not loaded. What gears are you running?
Old 03-16-2013, 08:12 PM   #29
Jon01
Jon01's Avatar
Re: LQ9 power
799 heads came on later model 5.3's and 4.8's as well as 07/08 LS2's.
They are identical to the old 243 heads. Some 07's came with one 243 and one 799.
FAST intake does not come with injectors or anything like that.
You could also put an LS6 on it if you're not going max effort.
If you're not building a show truck I'd just run f-body accy's.
You can sell your truck stuff for $150-200 and f-car stuff is usually around 350-400.
Jon01 is offline   Reply With Quote
Old 03-16-2013, 08:13 PM   #30
Mr. 250r
Mr. 250r's Avatar
Re: LQ9 power
not worth stroking a 6.0..... mind blown. lol check ls1tech or ls2gto or any sites in those sites and you will find more knowledge than possible i will eventually go with a 408 kit from texas speed and performance maybe some boost..
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 03-16-2013, 08:57 PM   #31
thotfulspot
Re: LQ9 power
I've looked at their 408 packages. Quite a bit of power I really don't need. I'll probably stick with the head, intake, and cam route. Can always add the 408 kit later. It pretty much doubles the cost of the swap. From reading it seems the biggest bang for the buck is the heads and cam.
I need to find the right oil and transmission pans for clearance. I'll probably put skid plates on them like my Jeep pans. Take a plasma cutter and put 3-4 slots lengthwise. Cut a heavy piece of steel or aluminum to size and ramp the front of it. Line it up with the pan and weld a bead so it seals the slot and connects the two pieces together. I've dragged oil and transmission pans over rocks with no problems.
