Old 04-08-2013, 11:58 PM   #26
83GMCK2500
Re: Success rate of hinge repair with just pins and bushings?
Wallered/hogged/egged, nothing new here to this Eastern WA farmboy.
I have put...3 sets? I think, of Dorman hinge pins and bushings in, and I have one thing to say. DO NOT BUY THAT CHEAP SH!T. They wear out fast, even when lubed regularly with a lithium spray. We put new pins/bushings, and a new striker set into a couple of trucks, in less than a year the doors were dragging on the striker bolts, and everything was adjusted beautifully when we replaced the parts.
I went and bought GM everything for my '83 a few years ago and the quality is so much better, very much worth the blue and white box with the blue square.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-09-2013, 11:55 PM   #27
JellyBeanDriver
Did you buy GM bushings and pins or entire hinges?
I wasn't crazy about pounding the pin in. I'm thinking it would stress the thrust face on the bushing from all the pounding.
That said, I wanted to drill a hole near the bottom of the pin to put in a cotter just in case down the road the pin works its way loose. Couldn't center punch nor start a hole with a drill bit due to the Dorman pin being hardened.
Was the factory pin hardened? I hacksawed through them pretty easily so I don't think so.
Seems the Dorman pin would hold up due to being hardened - as long as the bushing holds up.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 04-10-2013, 12:05 AM   #28
83GMCK2500
I bought pins and bushings. I don't believe that the hinge needs to be replaced unless the door has been over-extended or the pins wore into the hinge themselves.
Devin
New Daily, the '96
