Old 04-02-2013, 05:45 PM   #26
vgnope
vgnope's Avatar
Re: 454 bbc thrown out!!!
The guy at the shop seems to thimk the intake manifold gasket failed and the motor itself didn't have many hours on it. The cylinder walls still had the cross hatched grooves and the pistons weren't that abused either.
vgnope is offline   Reply With Quote
Old 04-02-2013, 06:30 PM   #27
Rich 5150 69
Rich 5150 69's Avatar
You may be real lucky, you going to use in your truck them...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-02-2013, 07:04 PM   #28
vgnope
vgnope's Avatar
I'll have to re ring the pistons, put new bearings, the whole 9..Thats if the motor and heads pan out.
Old 04-02-2013, 07:16 PM   #29
Rich 5150 69
Rent a ball hone, give the walls a quick cross hatch pattern, use cast iron rings, they seat quick, new bearings, seals and your good to go, use the same cam, buy new lifters...
Old 04-03-2013, 12:46 AM   #30
Captainfab
60-66 Nut
Since that block is setup for a factory roller cam, I would seriously consider going with a roller cam. Even if you can only afford a good used or new take out OEM roller cam and lifters. With the oils we have these days and all the problems with flat tappet cams going flat, I would hesitate to take the risk with a flat tappet cam. Especially in a fresh rebuild.
Old 04-03-2013, 03:27 AM   #31
vgnope
vgnope's Avatar
Assuming the block turns out ok, I'll ask what cam is a good choice since the block is gen vi, heads are gen v. What intake, carb (or TBI a better choice?), pully system, water pump, dist (HEI of course) is best for the application? I know the TH350 is not the first option with the 454.
Old 04-03-2013, 11:16 AM   #32
Chevy Fleetside
Chevy Fleetside's Avatar
this is what I did with my free 454... It came out of an 89 burb. I just put a Q Jet on it with a built 700r4 tranny. I yet to drive it.. oh and a stock pulley system from GM.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-03-2013, 12:33 PM   #33
vgnope
vgnope's Avatar
Is there enough clearance at the fire wall for the dist to sit the bb in there? I see where my mounts are and it looks possible that I can move the perch forward and set a bb. Pic is pass side at the perch/mount.
Old 04-03-2013, 12:37 PM   #34
Rich 5150 69
You need to check that block, but I believe that you`ll have to use an electric fuel pump as that one will not have a provission for the standard fuel pump..
Old 04-03-2013, 12:48 PM   #35
vgnope
vgnope's Avatar
I was reading somthing about the gen v and vi blocks not having the fuel boss, but if thats the case no biggie.. then I can make sure I am supplying the right amount of fuel pressure to the motor... Might even go as far as relocating the fuel tank..
Old 04-03-2013, 03:29 PM   #36
TommyDuncan
Good score!
My best friend was at the wrecking yard and saw a burned up 80's dually.
He noticed the Intake was aftermarket and looked a little closer...
...so was the block and heads.
The fire started in the cab and traveled into the engine compartment.
He got the motor for $200 since it was crispy...
He took it to work, tore it apart, and hot tanked it...
555 CUBIC INCHES!
It's going in his 66' El Camino
TommyDuncan is offline   Reply With Quote
Old 04-03-2013, 04:15 PM   #37
vgnope
vgnope's Avatar
Forget the motor..... NICE REFLECTION.... how many shots of clear you got on that bed?
Old 04-03-2013, 05:00 PM   #38
Chevy Fleetside
I cut the firewall to set the engine back. Others just move the perches to the forward holes and avoid this. I wanted my engine set back.
I also used tubular perches because the headers would not clear the stock ones on the left side.
Old 04-03-2013, 06:33 PM   #39
TommyDuncan
I guess it's not hijacking since it's your thread
I don't think he even knows how many coats of color or clear are on it at this point. After having work done at a couple different shops he decided to do it himself.
He burned through in one place buffing it and found some body work he wasn't happy with so it's been redone once and fixed more than once since then.
The 61 Brookwood wagon in the reflection used to be mine when it was sea foam green ( and a beater).
He has an LS6 and a 6 speed to go in the wagon when he gets around to it.
Old 04-03-2013, 07:03 PM   #40
vgnope
vgnope's Avatar
Hey Chevy Fleetside.. How far did you notch the fire wall to sit the motor in? Only around the valve covers or more, I only can see just a bit in the pic. Also, nice setup..
Old 04-03-2013, 11:31 PM   #41
Chevy Fleetside
I just measured were the heads would be then cut 3 lines out on the firewall and bent the metal back and welded in some patches. Not sure if you can see it in the picture or not. Here is my build thread. http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Some of it is good. Would I do it again? not really sure. PITB..
Old 04-04-2013, 12:20 AM   #42
heeroyue2002
fat old dude
heeroyue2002's Avatar
dang i usually scrap 454's
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 04-04-2013, 01:21 AM   #43
Captainfab
60-66 Nut
You have a few choices for motor mounts. The '67-'72 small block motor mount brackets bolt into the forward mounting holes. The '68-'71 big block motor mount brackets also bolt into the forward holes, but position the engine in between the forward and rear mounting positions. Then you can also use the motor mount brackets from a '73-'87 C20 or C30. These will also position the engine in between the forward and rear positions, but will use the better style (IMO) motor mounts.
Old 05-08-2013, 01:12 AM   #44
vgnope
vgnope's Avatar
Update folks.. Block is good, 60 over, roller motor. Heads good too.. Getting the crank polished and micd, rods checked for size.. Just dont know bout cam selection.. Is roller better any better than flat tappet? What are the pros/cons? Thanks
Old 05-08-2013, 07:39 AM   #45
chevyrestoguy
chevyrestoguy's Avatar
Roller is definitely a better way to go, especially with the quality of today's oils. For the past decade, the oil manufacturers have slowly started removing zinc from the oil. On a flat tappet cam, zinc is really critical because it helps cushion the extreme force between the lifter and the cam lobe. You can flatten a brand new cam lobe in minutes during initial break-in if you use a modern oil without zinc or a break-in additive.
The biggest issue with rollers is the price. The cams usually a steel billet, and they cost more. The lifters are more expensive as well. Actually, the factory (Delphi) stock roller lifter is a pretty good piece. It's heavier than an aftermarket lifter, but they're reliable, easy to find, and pretty cheap. I'm not sure how stout you want to make your engine, but you might be able to find a factory take-out roller cam with no miles for super-cheap. I used to get the catalogs for Performance Products, and they used to have an area called the "Broom Sheet" where they had lots of take-out factory roller cams for less than $50.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-08-2013, 07:41 AM   #46
pmkrew
Only downside to a roller is added cost. Do some looking around and you might be able to find a good used cam/ lifter set.
pmkrew is offline   Reply With Quote
Old 05-08-2013, 10:36 AM   #47
scottofksu
scottofksu's Avatar
That's awesome! Congratulations!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 05-08-2013, 11:18 AM   #48
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
I Have A Brand New Set On GM Roller Lifters and A Complete Gasket Set... Ill Give You A Smoking Deal!!!! Let Me No
Pros Of A Roller No Need To Break in A Cam...
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 05-08-2013, 11:27 AM   #49
66Submarine
66Submarine's Avatar
WOW! That's got to be the best find ever! I really wonder how it ended up on the side of the road. A big heavy 454 is worth a fair amount these days just in scrap iron!
66Submarine is offline   Reply With Quote
Old 05-08-2013, 12:57 PM   #50
chevyrestoguy
I was wrong on the business name. It's not Performance Products, it's Competition Products. Here's a link to the Broom Sheet:
http://www.competitionproducts.com/broom/
My build threads:
