Old 04-22-2013, 11:15 PM   #26
toeffer
Re: Just brought home my 1947 3100
Cam/Timing gear/Oil pump installed.
toeffer is offline   Reply With Quote
Old 04-22-2013, 11:27 PM   #27
andyd00
OOO I'm jealous. You got your truck over a year after I got mine and you already have the LS in it. Good choice on engine setup. Please keep us posted. I was gonna do one big turbo on a 6.0 LS for the 57. It would be nice to hear what hiccups you run in to. You gonna use the stock EFI setup? Will you have to use the EFI's gas pedal?
Last edited by andyd00; 04-22-2013 at 11:36 PM. Reason: Previous post answered my turbo question and bad spelling
andyd00 is offline   Reply With Quote
Old 04-22-2013, 11:31 PM   #28
toeffer
Originally Posted by andyd00 View Post
OOO I'm jealous. You got your truck over a year after I got mine and you already have the LS in it. Good choice on engine setup. You going with one turbo or 2? Please keep us posted. I was gonna do one big turbo on a 6.0 LS for the 57. It would be nice to hear what hiccups you run in to. You gonna use the stock EFI setup? Will you have to use the EFI's gas peddle?
I'm going with twin 70's I believe. I haven't decided if I will do a mega-squirt or hp tuners on the stock ecu.
I'm not familiar with the EFI's gas pedal.
I had a benefit of not having a motor when I got it and it was already setup for a small block. Pretty easy conversion at that point. I will love to see what you do when time allows!!
Old 04-22-2013, 11:36 PM   #29
andyd00
If it is a 06 or newer LS you may have to use the Gas pedal from the donor car. Otherwise the ECM gets angry. I know this cuz my 6.0 was sold to me with the pedal and was told it wouldn't run without it.
Old 04-22-2013, 11:52 PM   #30
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
your project looks killer.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 04-22-2013, 11:59 PM   #31
sqrlnts
So jealous. I have often dreamed of doing an LS swap. I am sure you have read the Hod Rod build that made 4.09 hp/ci ? Yes its not a longevity thing but that little motor took a beating until the ignition could not hold up. 1203hp on the stock long block with only regapped rings.
Great looking project!
sqrlnts is offline   Reply With Quote
Old 04-23-2013, 10:17 AM   #32
toeffer
Yes I have read it. I actually ordered my custom cam from the guy that wrote that article!! I won't be pushing the limits as much, but I plan on making over 700hp.
Old 05-05-2013, 10:56 PM   #33
toeffer
Got the timing chain cover/new seals/oil pickup/windage tray/oil pan installed. Next step waiting on ls9 gaskets and then the heads will go on.
Old 05-13-2013, 06:22 PM   #34
toeffer
Hotside parts are almost all here!
Old 05-13-2013, 08:27 PM   #35
let it loose
Junior Member
let it loose's Avatar
Nice set up!
let it loose is offline   Reply With Quote
Old 06-12-2014, 11:43 PM   #36
toeffer
I feel accomplished, I finally got to start work on the raised bed floor!!
Old 06-13-2014, 02:19 AM   #37
sqrlnts
Keep it up, what kind of upper bag mount are you using?
Old 06-13-2014, 09:57 AM   #38
NEWFISHER
NEWFISHER's Avatar
Its been a long year...looking good!
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 06-13-2014, 10:48 AM   #39
toeffer
We moved into a new house, and this thing has been tucked away in my brothers garage until last week.
I got a new fuel tank,pump, and my new air management system is on the way
Old 07-03-2014, 12:44 AM   #40
toeffer
A little more progress..
Old 08-05-2014, 10:13 PM   #41
toeffer
Got my rear crossmember almost done. First time doing any fab work like this, im pretty happy with the results so far.
Old 09-12-2014, 11:07 PM   #42
toeffer
Final assembly!
Old 09-13-2014, 12:46 AM   #43
toeffer
Just need to run a few more wires!!
Old 09-14-2014, 10:38 PM   #44
eagleuh1
eagleuh1's Avatar
Get that thing on the road so I can see it while I'm in Nebraska. Good work. Jim
eagleuh1 is offline   Reply With Quote
Old 10-07-2014, 09:06 PM   #45
eagleuh1
eagleuh1's Avatar
No progress in a month?
Old 10-15-2014, 10:09 PM   #46
toeffer
I got the motor cleaned up, just bought some 317 heads and got done replacing the valve springs with BTR springs, waiting on the trundle upgrade so I can bolt the heads on the motor and get the rockers/pushrods installed.
After that its time to drop the motor/trans in.
Old 10-16-2014, 09:34 AM   #47
Gippetto
toeffer:
Looks like the straight six was long gone when you bought the truck. I need a front motor mount assembly if you happen to have one. Locally I have had no luck finding one.
Gippetto is offline   Reply With Quote
Old 06-03-2015, 11:08 AM   #48
toeffer
Got some more work done, wiring, battery jumper terminals, on/off switch. The motor is in for good this time!
Old 06-03-2015, 11:13 AM   #49
eagleuh1
eagleuh1's Avatar
Looking good, but long gone from Nebraska. Nice work.jim
Old 06-03-2015, 11:21 AM   #50
toeffer
Thanks man! Did your work take you out of Nebraska?
