Old 01-20-2018, 08:45 PM   #26
Killer Bee
Killer Bee's Avatar
Re: NOS Cab Roof Marker Clearance Light Kit
Originally Posted by Aultro View Post
my marker lights turn off when the headlights come on. Would there be a way to wire the cab lights to be on with the markers and headlights?
not sure what model truck yer workin' on but the position of the h/l switch you're tapped into may be source of your trouble..
on my '65 C20;
  • h/l switch in the first position switches on the front and rear running lights..
  • h/l switch in the second position turns on the headlights and the front running lights turn off while the rear running lights remain on..
so this may also be the operation of the headlight switch in your truck..
if so, you would want the rear running light pole off the switch to activate the running lights..
without knowing the amp draw of the five lamps in your clearance lights or the amp rating of that position of the h/l switch, you may want to install a relay..
run the primary side of the relay through the rear running lamp pole of the h/l switch and run the clearance lamp circuit through the secondary side of the relay through a rated fuse or c/b to B+
I would look for a factory accessory tap on the main fuse panel but you may prefer to run directly to battery or a junction block you may have already installed..
if you can determine the h/l switch is rated for direct load, a proper splice there at the switch would be preferred..
you may also want to research the h/l switch p/n options to determine whether a higher rated h/l switch was used on factory clearance light equipped trucks..
if your not sure what you have, some basic circuit testing should solve your mystery..
good luck!
Old 01-21-2018, 11:14 PM   #27
Aultro
Killer Bee. My truck is a 67 and it appears to work the same as you described yours. If I got this right, your idea of wiring to the tail light pole seems right. that way the cab lights are on whenever the marker and/or headlights are on. great idea.
My buddy wants me to just run the cab light through a toggle switch that’s already in the dash. Not a bad idea but not what I prefer.
Aultro is offline   Reply With Quote
Old 04-29-2018, 09:13 PM   #28
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
RogerKoop is offline   Reply With Quote
Old 09-26-2018, 06:17 PM   #29
RogerKoop
RogerKoop's Avatar
I have 3 sets for sale
Roger Koop
Old 09-26-2018, 06:30 PM   #30
Killer Bee
Killer Bee's Avatar
I'll take a set, please quote total with shipping to 92683, thank you!
Old 09-26-2018, 08:09 PM   #31
RogerKoop
RogerKoop's Avatar
PM sent
Roger Koop
Old 09-26-2018, 08:57 PM   #32
Killer Bee
Killer Bee's Avatar
paypal sent, shipping address in the notes, thank you!
Old 09-27-2018, 12:54 AM   #33
AASmedic
AASmedic's Avatar
Hi Roger, I will take a set.
My Paypal address is: http://paypal.me/KFerguson66
72 K20 Cheyenne Super
My "re-build" thread
http://67-72chevytrucks.com/vboard/s...?t=710221&goto
Thread for my Reproduction Jack Bags
http://67-72chevytrucks.com/vboard/s...d.php?t=715455
AASmedic is offline   Reply With Quote
Old 09-27-2018, 04:08 AM   #34
ShortbedClayton
I will take a set of you have any left. PM me you info. Thanks Clayton
ShortbedClayton is offline   Reply With Quote
Old 09-27-2018, 01:55 PM   #35
RogerKoop
RogerKoop's Avatar
Going out today. Thanks
Roger Koop
Old 09-27-2018, 02:32 PM   #36
RogerKoop
RogerKoop's Avatar
PM sent
Roger Koop
Old 09-27-2018, 02:33 PM   #37
RogerKoop
RogerKoop's Avatar
PM sent
Roger Koop
Old 09-28-2018, 10:29 AM   #38
RogerKoop
RogerKoop's Avatar
1 set sold. Will ship today
Roger Koop
Old 09-28-2018, 10:30 AM   #39
RogerKoop
RogerKoop's Avatar
Sold, Will ship when paymnt received.
Roger Koop
Old 09-28-2018, 10:31 AM   #40
RogerKoop
RogerKoop's Avatar
I will get more sets in in about a week. So if you want one let me know.
Roger Koop
Old 09-29-2018, 02:54 PM   #41
Killer Bee
Killer Bee's Avatar
arrived today, as advertised, thank you!
Old 11-12-2018, 01:14 PM   #42
RogerKoop
RogerKoop's Avatar
Roger Koop
Old 11-12-2018, 01:42 PM   #43
Lanman1972
Lanman1972's Avatar
How about a set of gaskets only? Thanks
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 11-28-2018, 02:37 PM   #44
Bryce80
Bryce80's Avatar
I would like a set of these lights, how do I order/pay? I have not made a purchase through site before.
Bryce80 is offline   Reply With Quote
Old 07-31-2019, 08:05 PM   #45
RogerKoop
RogerKoop's Avatar
several sets available
Roger Koop
Old 01-01-2020, 01:34 PM   #46
Aultro
are these kits still available?
Old 01-01-2020, 07:04 PM   #47
RogerKoop
RogerKoop's Avatar
Yes I have several left.
Roger Koop
Old 07-29-2020, 11:34 AM   #48
RogerKoop
RogerKoop's Avatar
I have several sets for sale
Roger Koop
Old 08-16-2020, 06:19 PM   #49
72again4x4
72again4x4's Avatar
Hi Roger, I will take a set please.
Thanks, Roger M. 😃
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 08-16-2020, 11:12 PM   #50
RogerKoop
RogerKoop's Avatar
Thanks, Roger M. 😃
PM sent
Roger Koop
