Old 04-08-2013, 11:51 PM   #26
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Aluminum inner fenders?
I basically had the 12 bolt built for 10.0 seconds... But yes, we do know the weak point!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-09-2013, 01:10 PM   #27
69GMC910
MOTORHEAD!
69GMC910's Avatar
Update! I spoke with Tony at Goodmark and anything we would want in aluminum is possible, but would have to be in a minimum order of 150 pcs!!! He also explained to me that all the new pieces are lighter than stock anyways, and the aluminum would probably end up being heavier than the steel. The replacement inner fenders weigh 11 pounds whereas the stock weighed roughly 20. I think if I can save 18 pounds by changing out to a replacement steel, that is the route I will go! This same weight reduction also applies to fenders, though I didn't ask about weight differences. The way the metal is made is different than they did back in the day, so even though it is thinner, it still possesses the same strength as the original equipment. Thank you Insidious '86 for pointing me in the right direction!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-09-2013, 01:37 PM   #28
Keith Seymore
Keith Seymore's Avatar
Originally Posted by 69GMC910 View Post
Proof is in time slips, and my builder's engines are in all of the fastest BB steel headed Chevelles in the USA. If I told you my cam specs you'd doubt it even more!
Who is your engine builder?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-09-2013, 01:46 PM   #29
69GMC910
MOTORHEAD!
69GMC910's Avatar
Mark Jones @ VortecPro
http://www.vortecproperformance.com/...binations.html
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-09-2013, 02:18 PM   #30
INSIDIOUS '86
INSIDIOUS '86's Avatar
They use thinner gauge metal yes. Is it stronger than the original metal yes. But it flexes more like a cheap coke can. And how it can be heavier? Unless they at going thick with the stuff idk
Well next step is for 150 pieces we could do a group order. It will Prob take a long time but getting an order for 150 alum fenders shouldn't be to hard to sell. Inner fenders may be harder to sell since those Are sometimes ditched for racing or modded for lowered vehicles or most may not see the great point.
Lets see how far we can take this. Cause I'm all in
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-09-2013, 03:38 PM   #31
cory d
cory d's Avatar
aluminum fender/inner fender combo made for even 2" more tire clearance would be pretty shnazzy
cory d is offline   Reply With Quote
Old 04-09-2013, 04:20 PM   #32
63chevyll
gets board easy.......
63chevyll's Avatar
No way...when I was reading this I was thinking of mark..and now I see you use him.
He builds some nasty big blocks for sure. He is just a min from my house
Good luck getting your truck on the road.
63chevyll is offline   Reply With Quote
Old 04-09-2013, 04:45 PM   #33
69GMC910
MOTORHEAD!
69GMC910's Avatar
Awesome, tell him Jared says hello if you see him!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 10-16-2013, 12:40 AM   #34
INSIDIOUS '86
Any update in those alujerbin parts?
