Old 04-13-2013, 12:07 AM   #26
hatred
hatred's Avatar
Re: New shroud or switch to electric fan?
Originally Posted by SCHRUMGMC View Post
Probably because of me right ?
Yah its all you hahaha
05 QSM GTO - M6, Corsa, King Springs
70 SWB CST - 350/Auto, Foose 18/17
I upset whiners too....
hatred is offline   Reply With Quote
Old 04-13-2013, 12:11 AM   #27
hayhauler71
hayhauler71's Avatar
I had high temp problems when running a single electric fan that I bit the bullet and bought a dual 13 inch fan with controller. This fan puts out 4600 cfm. My upper hose temp now runs 180 and the lower is 121 after idling in stop and go traffic for a hour and a half. Here is a pic of both the set ups
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-13-2013, 12:47 AM   #28
JellyBeanDriver
Why does people Paint the Fans ?
GM painted our fan.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 04-13-2013, 01:03 AM   #29
SCHRUMGMC
SCHRUMGMC's Avatar
Haha
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-16-2013, 02:22 AM   #30
profe56
I was reading this thread on saturday night and the next day I went to junkyard and found two electric fans suggested by buckskins4ever but they are 95's not 98, I think they are 16 In fans. I like if is posible see a pictures how is mounted.
Next weekend I coul get it for 10 bucks.
profe56 is offline   Reply With Quote
Old 04-16-2013, 02:28 AM   #31
profe56
But. it took my attention the Hayhauler71 comment about using one or two fans.
Now the question is which option would be better one or two fans.
Old 04-16-2013, 03:06 AM   #32
mcmlxix
Collector of Projects
mcmlxix's Avatar
I bought the Jeep Grand Cherokee fan... It fits perfectly in the factory shroud... I'm doing an LS swap and it will be controlled by the PCM... I'll take some pics this weekend...
Also, from what I found, there are 2 Jeep GC fans... a single speed and a one year only 2004 two speed....
Rich
1972 K5 Blazer CST Click HERE
Old 04-16-2013, 04:52 AM   #33
Sammy
Just wanted to add. In his case 4WD he has plenty of room for the thicker electric setup and shroud. However in a 2WD application with the engine in the standard location you could be cramped for room. In that case you would need a slim designed set-up. I personally ran into that problem on my GMC. And used a pair of the thin/ slim Zirgo fans and a custom shroud.
Also the clutch failure risks has been noted before and well documented on here. Personally I would never use a used 30 plus year old clutch fan due to the dangers and damage they can do.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-16-2013, 08:04 AM   #34
SCHRUMGMC
SCHRUMGMC's Avatar
I may wanna get a Electric one.not sure yet
1971 GMC Sierra
1959 GMC 100
Old 04-16-2013, 08:45 AM   #35
54belair
54belair's Avatar
Hey Gene,,
If you dicide to do away with your stock shroud and go electric-------Id like to be first in line to buy your stock shroud (and/or clutch fan)
Just a thought!!!!
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 04-16-2013, 10:09 AM   #36
Leftlane
Elf...X3 on seeing pics.
I'm in the planning stages on cooling, and looking for solid working options.
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 04-16-2013, 04:38 PM   #37
Gene
Gene's Avatar
Originally Posted by 54belair View Post
Hey Gene,,
Just a thought!!!!
Well, the shroud has both tabs broke off the top and clutch is shot on fan, I plan on using old shrould to mount new fan in.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 04-30-2013, 05:32 PM   #38
Gene
Gene's Avatar
Ok, here's how it turned out. I have it wired to ignition for now but will add a relay soon. All credit goes to 71rat for posting the how to on changing to a Jeep Grand Cherokee fan.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 04-30-2013, 05:33 PM   #39
SCHRUMGMC
SCHRUMGMC's Avatar
Electric Fan
Normal Fan
What is the Pro's and Con's for each one ?
1971 GMC Sierra
1959 GMC 100
Old 04-30-2013, 05:38 PM   #40
Gene
Gene's Avatar
Electric Fan
Normal Fan
Electric fan=less horsepower robbed. I really cant think of a pro for a clutch fan other than if the electric one fails youre dead in the water, but if a clutch goes out you still have some air moving.
I really went this way because I needed a new clutch and the cost of it would have been greater that the 57.00 I paid shipped to my door for a brand new fan. I also woudl have needed a new shroud because mine isnt long enough for a factory clutch fan.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 04-30-2013, 05:49 PM   #41
SCHRUMGMC
SCHRUMGMC's Avatar
Then heck I am staying with Stock
1971 GMC Sierra
1959 GMC 100
Old 04-30-2013, 08:07 PM   #42
rogergodding
rogergodding's Avatar
I agree with the Jeep Cherokee fan....
http://67-72chevytrucks.com/vboard/s...d.php?t=569078
rogergodding is offline   Reply With Quote
