Old 10-09-2013, 11:15 PM   #26
54worker
Re: '55 Chevy Dually
This is sure gonna be un my watch list. Good luck man.
54worker is offline   Reply With Quote
Old 10-10-2013, 08:32 AM   #27
L_Brown
L_Brown's Avatar
Now this is going to be sweet. I love it!!!
Larry Brown
North Texas
My 1956 Build - Huff Truck
http://67-72chevytrucks.com/vboard/s...48#post6308448
L_Brown is offline   Reply With Quote
Old 10-10-2013, 10:49 AM   #28
99 to Life
99 to Life's Avatar
love the trucks, the ideas and the motivation.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-24-2013, 05:07 PM   #29
Racker
Racker's Avatar
Well the weather was FINALLY good enough to be able to go and rescue the donor body for the crewcab part of the build. Not going to start on this right away, going to get the standard cab running and enjoy it for awhile (OK, thrash the hell out the 468cid that will under the hood.) This will be parked in the back yard for later rebuild of the cab. Almost feel bad for cutting it up but I couldn't beat the price.
Life is not ment to show up at the grave in a well preserved body....but to show up in a well worn out body, sliding in sideways yelling, "WHAT A HELL OF A RIDE !!!!!"
Racker is offline   Reply With Quote
Old 10-24-2013, 06:33 PM   #30
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Going to be a very interesting build.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 10-24-2013, 06:48 PM   #31
arturo7
arturo7's Avatar
Hmmm...
As long as your cutting it up. I wonder if it would be feasible to ship the rear quarters to Socal? Just thinking out loud.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 10-24-2013, 10:59 PM   #32
Racker
Racker's Avatar
Originally Posted by arturo7 View Post
Hmmm...
Depends on how much of the quarter are you wanting? They are not in the best of shape but if your truly interested in them, I can get you better picture. Your paying for shipping thou.
Old 10-25-2013, 01:03 PM   #33
arturo7
arturo7's Avatar
OK thanks, they are in much better shape than mine. The whole body is in better shape for that matter...
Let me look into the costs.
ever forward
Old 12-05-2013, 07:42 PM   #34
Racker
Racker's Avatar
Quick update, will post pictures hopefully this weekend. Started boxing the frame in for motor mounts and extra support where I cut the frame to narrow it up. Also got the motor mounts built (frame side) and motor is bolted into the frame, ended up being able to use some Energy Suspension off the shelf mounts(motor side), at least this way they are kind of a easy part to replace if need be. Oh yay, a buddy of mine brought me over a aluminum radiator that I think will fit, it was in his small block s-10 before he tore it apart (FREEBIE). Ordered trans. mount today, hopefully be here in time for next weekend so I can get it mounted also. Also ordered a set of weld-up lakester style headers that I will modify to be fender well headers.
That's about it all for now, like I mentioned, will try and get pictures posted this weekend for all you PICTURE HOODS.
Old 12-16-2013, 10:36 PM   #35
parks
parks's Avatar
nice work keep it up. could you post more pics of the frame work.
parks is offline   Reply With Quote
Old 12-16-2013, 11:02 PM   #36
skymangs
skymangs's Avatar
HOOKED!
This is going to be a gnarly build!
skymangs is offline   Reply With Quote
Old 01-01-2014, 11:17 AM   #37
Racker
Racker's Avatar
Started boxing in frame where I cut it to move it in for tire clearance when laid out. Also fab'd up motor mounts to work off the boxing.
Passenger side
Motor finally in its position. Was worried about finding/building mounts for power steering pump but after spending a few days looking at it, I found out I had the brackets already. Will post pictures later.
Transmission fits pretty good in original opening, hoping with a little modification I can use the original floor access cover, will make putting in the floor shifter ALOT easier.
Old 01-01-2014, 11:30 AM   #38
Racker
Racker's Avatar
Motor to firewall clearance. Not sitting back as far as I was hoping for but had to make room for the dist.
Got the transmission cross member built.
Cross member installed. Sorry for the HORRIBLE picture, reached under the cab and shot the picture. Was able to keep everything above the frame rails and built it low enough that I'm going to try and sneak my exhaust back through the frame rails and run them inside the frame.
OH YAY, a friend of mine brought over some over the frame headers and with a little massaging of the front primaries, I can make them work. These should let that little motor breath, 2" primaries and 3" collectors. So it looks like a lot of the things I was worried about after wedging the front frame rails in 4" are coming together.
That's about it for now, working on rebuilding door hinges and waiting on parts for now.
Old 01-01-2014, 12:58 PM   #39
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
