04-24-2013, 06:50 PM | #26 | ||
Re: computer tune and harness mods?
Im going to start on Truckdudes pinouts PLEASE do not post in the middle of my posts. |
04-24-2013, 06:52 PM | #27 |
Okay I will try and find a fuse box
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-24-2013, 07:12 PM | #28 |
Underside view of the fuse box, The black connector on the engine harness will bolt to C2.
04-24-2013, 07:30 PM | #29 |
C1, Grey plug....
Pin A6, This will be the new Ignition source for the transmission. Pin A9, Hook an Ignition hot here (This powers all Ignition hots on the engine.) Pin C9, Hook it to Pin A6. Pin C12, TCC brake wire (goes to a Dual Brake Switch) to cancel lock-up. |
04-24-2013, 07:33 PM | #30 |
C3, Red plug...
Pin F1, Fuel Pump Power. |
04-24-2013, 07:45 PM | #31 |
There will be a 2nd small black plug on the harness near the C2 connector, Ask later if confused.
Black C100 connector... Pin D, VSS output (speedometer) Pin G, Check Engine Light. Pin H, ALDL, (serial data, Goes the data link connector) Pin K, Tach output. |
04-24-2013, 07:51 PM | #32 |
OK Im done, Any questions Truckdude?
04-24-2013, 07:53 PM | #33 |
When I hook c-9 to a-6 do I still need the power feed or do I double the wirr
04-24-2013, 07:54 PM | #34 |
Also pin h feeds the obd port series the best place to wire it?
04-24-2013, 09:00 PM | #35 |
also will this switch work? http://shop.advanceautoparts.com/web...973104-P_422_R
i guess i'll need 12 volts to it and when i hit the brakes it closes and sends power to the Pin C12 of the c-1 connector right?
04-24-2013, 09:08 PM | #36 | ||
Pin 4 & 5 will need to be grounded. Pin 16 will need a Battery Hot. |
04-24-2013, 10:34 PM | #37 | |
Any updates on this decision ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-24-2013, 10:39 PM | #38 |
Thanks, I re read the earlier post !!!!!
Are you still having fun, at least you will know where each circuit wire starts and terminates !!
04-25-2013, 12:58 PM | #39 |
17's too small
Daaaanz67, Is that the SA-1000 Engine Management Fuse Block? Could you post a picture with the doors open? All of the ones on their website are too small to see any detail.
Thanks, John
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
04-25-2013, 02:13 PM | #40 |
Yes just given me a little time.
Posted via Mobile Device |
04-25-2013, 07:12 PM | #41 | |
04-25-2013, 07:16 PM | #42 |
10-4
04-26-2013, 12:32 PM | #43 |
great info thanks for posting this
04-26-2013, 02:13 PM | #44 |
Cline - don't waste you're time on my setup. I got to thinking that my old harness probably won't work because I converted my motor from a L99 to a LS3 (deleted VVT and AFM). I do appreciate your offer,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-03-2013, 03:56 PM | #45 | |
05-03-2013, 05:24 PM | #46 |
Cline, thanks for the great info. That looks incredibly easy to wire (far easier then my current TPI setup).
