05-02-2013, 09:54 AM | #26 |
Boosted Member
Re: mafs to speed density
I just find that I can get them to run so nice with the MAF failed, that I ditch it alltogether
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
05-02-2013, 12:24 PM | #27 |
Thanks for the link. That was great reading.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-02-2013, 01:17 PM | #28 | |
Boosted Member
Lol, I love how the MAF vs SD debate is kinda like "blondes vs brunettes", "pepsi vs. coke", "tastes great vs less filling", or even..."chevy vs ford". Lots of passionate opinions, but really no wrong or right answer. Whatever suits you best.
For reference, here's where I have mine mounted. Works great. And...omg, look ma, no MAF!
05-03-2013, 09:12 AM | #29 |
I'd SD your truck vs MAF in a heartbeat. Centri/turbo apps are much better suited to SD tunes than N/A stuff IMO as they overcome changes in elevation/temp as soon as they climb into boost.
05-03-2013, 09:29 AM | #30 | |
Boosted Member
You're probably also going to hate that I never run narrowband O2s either I built and tuned my brother's LSx Monte Carlo SS in Illinois, and it's running door to door with procharged C6 corvettes down in the heat of Texas. Tuned open loop, speed density, and the tune hasn't been touched since I gave it back to him. I also tuned my N/A LSx jet boat OLSD. Ran perfect in all conditions. Would it have run "better" in certain conditions with O2s and a MAF? Maybe, but my money is that it wouldn't have been enough to notice. Plus, it cleans up the look a ton.
05-03-2013, 11:04 AM | #31 |
MAF's are there for redundancy and simplicity.
OEM's produce millions of vehicles that see all sorts of climates, they have to run fantastic in Alaska and down by the equator without tune changes. That's why they have them. I don't care what you do with your car. I run 1 narrowband and 1 wideband in my junk while tuning and replace it with another narrowband once done monkeying with the tune. Only reason is that WB NGK sensors are spendy otherwise it'd WB all the time. |
05-03-2013, 05:30 PM | #32 | |
and BTW Ford switched to SD on the eco boost engines. |
05-04-2013, 12:15 AM | #33 | |||
In addition, if you keep narrow bands (which I personally don't but do in most customers cars) they will self correct your ltrims to keep your closed loop AFR for gas at 14.7 or what ever you have set as you stoich in the tune (they really shoot for lambda, so if you adjust stoich in the tune for E85 they will shoot for stoich). Nothing wrong with SD in an NA set up. Have fun getting a big cam to idle well when there is a lot of overlap and reversion. Quote:
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
05-04-2013, 12:15 PM | #34 |
meowMEOWmeowMEOW
Hey wasted;
with the weather in the 50s to low 60's, I was getting anywhere from 79 (right away) up to 115-120, when it warmed up into the 70's, I saw anywhere from 90-135*...maybe a tiny bit higher sitting in traffic. The interesting thing with looking at it how freaking erratic it is. I would get those 20-30* temp swings back and forth (we had REALLY weird weather tho). Obviously I'm not driving with HPT plugged in, but I'd be interested to see what it's seeing. Moreover, you make me just want to put a turbo on and stop having this discussion lfmao.
05-04-2013, 02:49 PM | #35 | ||
Boosted Member
Good info...I did not know that. Interesting.
Beware of the boost route...it's an addictive and slippery slope my friend
05-04-2013, 04:31 PM | #36 |
The turbo looks nice in there. Too bad I've got to much to do before I could afford that.
Posted via Mobile Device |
05-05-2013, 06:39 PM | #37 |
I sure don't care for innovates stuff. Lc-1's have given me nothing but problems. I take an AEM Uego over an lc1 any day of the week.
What gets me is the people that have zero first hand experience tuning that pipe in with what is better. I am not saying sd is bettter in all areas, but for what I do and my customers, sd is the better option. How many of us drive from say negative 2500 elevation to 5000' regularly. And if we do, who says your tuner got those areas right on the maf tqble to begin with. Posted via Mobile Device
05-05-2013, 09:30 PM | #38 | |
Boosted Member
I also have an AEM Uego now, and it's definitely awesome
05-05-2013, 09:47 PM | #39 |
I made the mistake of buying a 92 Camaro with SD, and when I put a hotter engine in it I could never get it tuned right.
Yes it was more my fault than the car's, but if your not experienced it could be a frustrating experience. I was ready to go to a FAST XFI system, but got rid of the car instead.... |
05-05-2013, 09:53 PM | #40 |
Boosted Member
A 92 TPI car?
That's not a very good comparison with a custom operating system 0411 based setup. If you have to burn chips....it's not tuning. It's guessing, lol.
05-05-2013, 10:05 PM | #41 | |
I
I wound up with a Moates emulator and was able to tune in real time with a laptop and wideband O2 system. By that time though, I was sick of the car and wanted it gone. It made almost 300 rwhp with a pig rich tune - I figured there was another 30-50 in the tune, if I could have found it. |
05-05-2013, 11:18 PM | #42 | |
05-09-2013, 08:00 PM | #43 |
Wasted - Do you know the part # for that sensor you have circled? Also, where did you get the plug and what port in the ECM does it go to? Do i just put it into an empty port and tune it to recognize whichever one it is?
Check out my build: 1972 LQ4 Swap http://67-72chevytrucks.com/vboard/s...=1#post5427693 |
05-09-2013, 08:02 PM | #44 |
Also, do you think that the front fuel rail connector you have wuold go over the LSXRT manifold and 92mm throttle body?
05-10-2013, 01:49 PM | #45 | ||
Boosted Member
http://www.diyautotune.com/catalog/g...tail-p-62.html It gets wired to the IAT wires that are part of the MAF connector. I don't have a schematic in front of me to tell you exactly which ones. In the past, I've just cut off the maf connector and wired right to the 2 wires there. If you do that, the ECM will recognize it as IAT, and no recalibration is necessary. Quote:
It's just -6 braided hose for the crossover to the regulator....make it any length you want, and route it any way you want. Also, themb2g....what vacuum booster is that? My hydroboost is a huge POS, and looking to possibly go back to vacuum.
05-12-2013, 01:27 PM | #46 |
Thanks Wasted, your info helps a lot. The brake master/booster/proportioning valve all came from LMC or Brothers. I cant remember now. I cant tell you how well it works yet though as I havent ran the truck since installation of it.
09-05-2013, 07:40 PM | #47 |
A day late and $1 short...
I have a N/A 5.3L/4L60E with a GM hot cam that has been tuned locally. I am having trouble with locating my MAF sensor due to a change in accessory brackets, the Holley brackets put the power steering reservoir where the MAF used to be. I moved it towards the drivers fender to account for this and it did not react well, so for now it is located directly on the TB which works but looks horrible. I talked to my tuner and he said he can rescale it to adjust for the move, but all of this makes me more curious about ditching the MAF all together and swapping to SD. There are many differing opinions in this thread though, so I guess I need to read up some more. The only reason I'd be doing it is to make the air intake cleaner and easier to reconfigure if needed. I'm trying to clean up the look of my installation so I'd like to know more about the pro/con for using SD as well as the advantages of wide band vs narrow band O2s. Is there a single book I can read to answer these questions?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
09-05-2013, 10:11 PM | #48 |
My MAF was on the TB from the start. I cant say very much on MAF vs SD as i just got my truck running so i havent been able to measure performance.
09-06-2013, 11:45 AM | #49 |
No book, but lots of info on HPtuners forums.
09-06-2013, 03:08 PM | #50 |
Have you looked at the air cleaners with the MAF built in by Street and Performance?
http://www.hotrodlane.cc/ Posted via Mobile Device |
