Old 05-14-2013, 05:26 PM   #26
of13swc
Re: Frame cut
I sure will. Getting everything together that I need. I think my plan is to fix where is was cut weld it all solid and weld in a plate in the inside of the frame where they cut. Put in the porterbuilt notch not the super notch just the small one. And box in the other side of the frame for extra support. Then put the factroy rear crossmember back. I will post pictures as i go.
of13swc is offline   Reply With Quote
Old 11-07-2014, 08:21 PM   #27
of13swc
Re: Frame cut
OK well here I go. I know its been a while but finally at it. this is the start. So the blocks is what was in it. Funny what some people will be fore more drop. And the last one is what they uses in place of the original cross member. I will be putting the original style back in. I will also be adding a c-notch and 5" lowering springs. Of course once if fix what is already there.
Old 05-05-2015, 02:40 PM   #28
of13swc
Re: Frame cut
Removed old hack job. replaced and put in CPP notch
Old 05-05-2015, 02:42 PM   #29
of13swc
Re: Frame cut
Painted frame with tires on and fuel tank in
Old 05-05-2015, 02:51 PM   #30
of13swc
Re: Frame cut
Bottom left was before the drop spindles but, got the front lowered also. 7" in the rear. 5 in drop springs 2" lowering blocks in rear and 2.5" drop spindles and 2" drop springs (I think front springs were in there when I bought the truck).
Old 05-06-2015, 03:35 PM   #31
T Smith
T Smith's Avatar
Re: Frame cut
Sweet, good job!
T Smith is offline   Reply With Quote
Old 05-06-2015, 05:58 PM   #32
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Frame cut
Nice job. Off topic, I am typically not a big fan of hood scoops/cowl hoods on this era trucks but yours looks sweet.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-06-2015, 06:26 PM   #33
of13swc
Re: Frame cut
Thanks guys
