#26 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: HO52 to 14 bolt
I've purchased two within the last 18 mos both were ~ $300 each w shipping.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#27 |
Re: HO52 to 14 bolt
Let me stand corrected, if you have an automatic and are looking at saving a few bucks then you might not need to spend the money on calipers with the integral parking brake, however unless you are just using the truck to go to the grocery store I would not recommend it.
Unfortunately there is no locker in my old unit. However, I am willing to let it go for a few hundred. If you find a locker that will bolt right in then it might be a goo opportunity to rebuild what is on the ground then just swap it in. |
#28 | |
Re: HO52 to 14 bolt
#29 |
Re: HO52 to 14 bolt
Possibly. Lot of them have a check valve in the port for the rear circuit. Usually if you pull the line there is a separate piece in there (cone) that the line seals to, pull that and the check valve would be behind that. There are some that have the check valve in the prop valve.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#30 |
Re: HO52 to 14 bolt
A disc/drum master cylinder might have enough fluid volume for rear disc brakes but I'd make sure first. But if you change the fronts you will need to install a disc/drum master cylinder and prop valve. With rear discs you will need an adjustable prop. valve to keep from locking the rears. In any event a brake booster is needed too.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#31 |
Re: HO52 to 14 bolt
is there a disk brake conversion for the front of this truck? seems ive looked everywhere and cant find anything for a 20. might just stick with the drums, dont really need the stopping power or spend money on something like that
#32 |
Re: HO52 to 14 bolt
72's had disc brakes. Probably the 73 and later may well fit also.
#33 |
Re: HO52 to 14 bolt
so back to my question. should i buy a complete new axle and swap it (dana 60, or 14 bolt), look for a locker for my eaton, or use a 14 bolt detroit and 14 bolt axles. i see several 14 bolts on ebay with the g80 locker option, could i buy this then swap the lockers over? what version of the 14 bolt should i look for? full float, semi float, 9.5, 10.5????? not an expert on these axles
#34 |
Carpe manana
Re: HO52 to 14 bolt
#35 |
Re: HO52 to 14 bolt
thanks guys, this thread has been great, really helped me alot!
#36 |
Re: HO52 to 14 bolt
Just saw this on craiglist http://milwaukee.craigslist.org/pts/3743089377.html
not sure how much is different between the single and dual axle configurations. I have yet to change my prop valve. My rear tires do not lock, i stop on a dime. Someday i will change it to get a shiney part. Check out this thread for additional width inforamtion http://www.planet4x4.net/forums/showthread.php?t=7413 another thing would be difference in the wheel studs. Last edited by my67c20; 05-01-2013 at 12:53 PM. |
#37 |
Re: HO52 to 14 bolt
To clarify: When doing a full disc/disc conversion you should use an adjustable prop valve to balance the system. If you do not use a valve at all or use the drum distribution block the rear brakes can lock up first depending on caliper sizing and pad choice. If you use a stock disc/drum prop valve, the pressure reducing feature of the prop valve limits the effectiveness and application rate of rear discs.
#38 | |
Re: HO52 to 14 bolt
Read and plan. http://67-72chevytrucks.com/vboard/s...68&postcount=4
