#26 |
C/10 junkie
Re: pinion angle @ ride height
Is it only over 5o mph? Any vibes on take off or hard acceleration?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#27 |
C10 CLUB Y QUE!
None
Posted via Mobile Device |
#28 |
C10 CLUB Y QUE!
Funny things is ive been having this issue before a change my front end to dropmember.
When I drove to LA both times it ran with no issue then I was slowly starting to get this issue. Could It be a ujoint or carrier bearing? I have a small amount of play in the carrier bearing but the rear ujoint has no play Posted via Mobile Device |
#29 |
C/10 junkie
A center carrier bearing that has play will vibrate..
#30 |
C10 CLUB Y QUE!
hmmmmm
well i guess im going to have someone take a look at it. first before a change it. |
#31 |
C10 CLUB Y QUE!
where do i place the angle reader on the tranny to get a true angle reading?
#32 |
I pull the yoke off and stick it to the face of the output shaft
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#33 |
![]() Join Date: May 2011
Same here
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
#34 |
You can also use the starter pad or the pan rail if you want to leave the driveshaft installed.
BTW, Its not "common practice" to just dial in 2 degrees of pinion angle in case the pinion angle just happends to change. On a street car not using leaf springs, there is no axle wrap.
![]() Last edited by wraprail; 06-11-2013 at 09:00 AM. |
#35 | |
C10 CLUB Y QUE!
im confused what is starter pad and pan rail? i just need more detail.. |
#36 | |
#37 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#38 |
C10 CLUB Y QUE!
Here's my numbers
Tranny. 5 Shaft1. 3 Center 0 raised 2 inches Shaft 6 Differential. 0. Posted via Mobile Device |
#39 |
C10 CLUB Y QUE!
Haven't tested yet
Posted via Mobile Device Posted via Mobile Device |
#40 |
C10 CLUB Y QUE!
Shouldn't it look like this
Tranny 5 Shaft1. 4 Cent b. 0 Shaft2. 6 Dif. 3 0r 5 I keep reading that my differential needs to be 1 from the first shaft but level with the tranny ? Posted via Mobile Device |
#41 |
C10 CLUB Y QUE!
Fixed!!! Change my differential up by 3° match my first shaft 3° down
#42 |
C/10 junkie
Yay!! Just in time for Brothers
![]() Posted via Mobile Device
#43 |
C10 CLUB Y QUE!
Lol nope not this year....=( no money...
#44 |
Can you post some pictures?
#45 |
C10 CLUB Y QUE!
I'll try
