Old 05-04-2013, 06:30 PM   #26
dunyet
Re: '68 Why did you do that
And then the engine/trans was test fit, along with the cab
dunyet is offline   Reply With Quote
Old 05-04-2013, 06:41 PM   #27
dunyet
At this point, the top of the transmission was hitting the Low hump floor board. I searched around for high hump but struck out. I've seen others on the forum build them from scratch. I figured I'd take care of the firewall at the same time because I wasn't happy with what I done so far on the Passenger side. So, I cut it up.
Old 05-04-2013, 06:45 PM   #28
dunyet
final fitting of the steel and test fit on frame to check for engine transmission clearance
Old 05-04-2013, 06:49 PM   #29
dunyet
Here's a few pics of the last two weeks worth of work. purchased a few odd and ends lately. 2.5 inch drop Mcgaughys spindles (73-87) as Dave w/Porterbuilt set up the A-arms for these style ball joints
Old 05-05-2013, 04:01 PM   #30
dunyet
I need some help with the location of the Porterbuilt front upper shock mounts. before ordering the mild dropmember I welded up alot of holes in my frame and welded up the hole that located the shock mount. does the below pic look right? or should it move a little aft.
Old 05-05-2013, 04:37 PM   #31
Xeen
Xeen's Avatar
The more straight up and down the shock is the better so you can put it where ever it needs to be to accomplish that.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 05-05-2013, 08:13 PM   #32
dunyet
Here's what I ended up with on the upper shock mounts. I just tack welded in place. Anyone see a problem with the location?
Old 05-06-2013, 09:33 AM   #33
Slammed66
Needs a Big Block
Slammed66's Avatar
Very cool build. Your not afraid to dive in, count me in
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 05-07-2013, 07:08 PM   #34
dunyet
thanks for the comment Slammed66.
I've got a little mad money (that's what I call it when the wife doesn't know...), I was thinking about buying the Slosh Tubz or the Porterbuilt hood hinges with gas assist shocks. I bought some Inner fenders from LMC last year, but since put the dropmember in so I'm not sure the inners will work. I really want to try to the Cab finished up so I can feel an accomplishment so I don't get discouraged so I guess i'll spring for the hinges.
Old 05-08-2013, 08:44 PM   #35
dunyet
I went ahead and purchased the gas assist hood hinges today from Porterbuilt. Dave said i should have in about 3 weeks. I guess I'll get the front fenders and radiator support mounted back up so I'll be ready to put the hood to test fit the hinges later. I guess I'll wait a little on the inner fenders
Old 05-08-2013, 10:13 PM   #36
faribran
Dunyet, Looking good. I am rooting for ya' from the EAST side of AL.
faribran is offline   Reply With Quote
Old 05-10-2013, 04:55 PM   #37
dunyet
Thanks. I always tell everyone I'm from LA. (Lower Alabama) I guess you could say you're from " East LA
Old 05-14-2013, 01:20 PM   #38
dunyet
here's what I accomplished this weekend. I fabbed up the gas tank out of .125" SSTL. I put two baffles in it. Not sure on the fuel pump yet (in tank or external). I just have it tack welded. I didn't have the tri-gas mixture to mig the sstl.
Old 05-14-2013, 01:37 PM   #39
67c10rustbuket
67c10rustbuket's Avatar
Wow great job so far! I love it
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-14-2013, 07:27 PM   #40
dunyet
Thanks Dan, I've following your build although I'm not "subscribed" come to think of it.... I don't think I'm subscribed to anyone's build. As a matter of fact I've thought about using your redneck dent puller idea, where you welded a bolt the corner of the bed. I have a dent on the back of the cab that is a pain to get to from inside that is just above the bed when it's sitting on the frame, I've seen where others would cut out the inside of the cab to fix the dent, I'm just not big on causing more work than I've already caused myself!!
here's what I'm talking about, if anyone has any suggestions let me know.
Old 05-19-2013, 08:06 PM   #41
dunyet
worked a little today on the truck..still need a name... seems to unpersonal to call it a truck still as much time as I have spent.
finished welding the gas tank today and decided to put it back in the frame so I could weld some mounts on it. Then I got to thinking what if I mount it too high. So I put the bed on it to check for clearance.. I think I need to cut the mount under the bed to make a little more or I'll cut the tank down a little. it seems a little high.
Old 05-19-2013, 08:12 PM   #42
dunyet
I got a little frustrated with the bed and gas tank becuase I have some additional work to do now. So, I moved to front end. I figured i better start getting the fenders back on so when my Porterbuilt Hood hinges come in, i'll be ready to fit and weld them on. Well, the first thing I pulled out of the "parts pile" was the radiator support. I was rusted through on bottom - Both sides! so I cut it out and made some new pieces, and welded them up
Old 05-19-2013, 08:17 PM   #43
dunyet
After I finished welding both the bottom repair pieces of the radiator support, I was going to mount the driver's fender. You have to check this out. The PO must have used spray foam to hold the bottom of the fender to the rusted out radiator support or thought it would be good for rust protection. I looked at the passenger side it has the same thing
Old 05-30-2013, 08:47 PM   #44
dunyet
well it was a long weekend. didn't get a whole lot done on the truck. I stripped (tried) the rust and paint off the radiator support. then i worked on the front fenders. Man that spray foam in the inside of the fenders was a PIA. Monday I worked on the drivers side door. still have some repairs to the drivers door
Old 05-30-2013, 08:49 PM   #45
dunyet
I know i like looking at all of your pics so here's more
Old 05-30-2013, 08:52 PM   #46
dunyet
Question Re: '68 Why did you do that
a few more, the door nor fender are fit just have a bolt or two holding it on for now. what do you think?
Old 06-03-2013, 09:31 AM   #47
dunyet
Didn't get to work on the truck Sunday, but Saturday I decided to go ahead and strip the paint on the rest of the bed, found some rust in the typical places got aggrevated and decided to just go ahead tear it down like the rest of the truck. The rust on the passenger side has just about eat out the lip over the wheel.
Old 06-03-2013, 10:47 AM   #48
builtbyKane
builtbyKane's Avatar
Great looking work. Way to get down to the nitty gritty and do it right.
builtbyKane is offline   Reply With Quote
Old 06-03-2013, 11:14 AM   #49
Str8-6-68
Str8-6-68's Avatar
subscribed, this build is coming along very nice. looks good
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 06-04-2013, 08:56 PM   #50
dunyet
Thanks Guys
The wife called today and said UPS dropped off two boxes today.. couldn't wait to get home to open them. Guess what, I had two complete sets of Porterbuilt hood hinges. I emailed Dave he's going to send a UPS label to send the other set back. How often does that happen! I figured they belong to one of you, and if like me have been patiently waiting so hopefully a couple more days and you'll have yours too!
