Old 06-03-2013, 04:10 PM   #26
mej005
Re: 1981 Stepside 5.3 swap
Originally Posted by Sodell View Post
That dash looks great, how much did you use from the donor truck?
What size tires are you running?
Sorry for the questions but I hate to spend money on a n after market dash when I could have the look you achieved, awesome idea!
Thanks, I used the entire dash from a 64-66 C10 and added more metal to make it fit around the windshield and A pillars. It was also widened a couple of inches. The tires are 255/60/15 on the front and 275/60/15 on the back.
mej005 is offline   Reply With Quote
Old 06-03-2013, 04:44 PM   #27
83 Silverado
83 Silverado's Avatar
Truck looks great and I like the dash swap, but I'd like to know if you re-work the stock wiring for the 5.3 or is it a aftermarket harness.
83 Silverado is offline   Reply With Quote
Old 06-03-2013, 10:06 PM   #28
dsanc754
Did you have to use the dirty dingo mounts or could you have made it work without them? And where did you get your wiring harness from?
dsanc754 is offline   Reply With Quote
Old 06-04-2013, 09:31 AM   #29
mej005
It's the stock 5.3L harness, I just reworked it using diagrams and instructions from lt1swap.com. I also built my own fuse block using parts shown on there also. It wasn't hard to do it was just time consuming.
I used the dirty dingo mounts for the adjustability. The engine I have has the mechanical fan and I wanted to be able to put it in the fan shroud where it needed to be. I could have made it work with just the adapter plates, but I wanted the adjustability.
Old 06-04-2013, 11:36 AM   #30
dsanc754
what did you use to mount trans?
Old 06-04-2013, 01:59 PM   #31
mej005
I used the stock crossmember, just redrilled holes to move it back.
Old 06-28-2013, 12:13 PM   #32
dsanc754
did you have to swap oil pans or did it just because you dropped the truck?
Old 06-28-2013, 12:47 PM   #33
Jonboy
Slots go on anything!
The truck looks great! Just a few questions, though. 1. What exhaust manifolds did you use? 2. What did you use for a radiator, or more specifically- how did you deal with the steam hose? 3. did you modify the gas pedal (DBW) or is yours using an accelerator cable?
Old 06-28-2013, 08:48 PM   #34
mej005
I didn't have to swap pans, I only did it for clearance because of the drop. The stock truck pan works, but it hangs down to low for my comfort.
I'm running tbss manifolds, stock 4 core radiator with 2000 silverado upper and lower hoses, and the steam port ran to the upper hose using an adapter I got at Jegs. It's dbc and I was able to use the cable from a 2000 silverado with the 1981 pedal.
Old 06-28-2013, 11:37 PM   #35
Jonboy
Cool, thanks!
Old 06-29-2013, 02:37 PM   #36
mej005
Originally Posted by Jonboy View Post
Cool, thanks!
No problem, if you think of anything else don't hesitate to ask.
