Old 09-08-2013, 04:26 PM   #26
Katrina/10
Katrina/10's Avatar
Re: Project: Family Heirloom
Thanks, I was wondering how that happened!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-08-2013, 09:05 PM   #27
selfbuiltrods
selfbuiltrods's Avatar
No problem!
-Dustin "self built" Self
Family Heirloom Project: http://67-72chevytrucks.com/vboard/showthread.php?t=579169
selfbuiltrods is offline   Reply With Quote
Old 10-22-2013, 07:53 PM   #28
yawdie1
yawdie1's Avatar
HOLYCRAP!!!! WHAT JUST HAPPENED!! when did? how did? um..
what?
You guys are fast! I still have to get my frame sandblasted and then figure out how to install my front cross-member!
tell you what. why don't you guys come work on my truck. And then I will wake up 3 days later and it will be done!
Good job guys!
1950 chevy PU work in progress.
yawdie1 is offline   Reply With Quote
Old 10-22-2013, 09:26 PM   #29
yawdie1
yawdie1's Avatar
Originally Posted by selfbuiltrods View Post
Today I got the rear suspension tacked together minus front gussets on the air bag plate and shocks. Hopefully this coming week the rear gets finished along with installing the air tanks (two, three gallons), the 20 gallon fuel cell, and the front suspension.
The rear end is from a Mazda pickup (so I could keep six lug and my factory wheels) The downfall is that its has 3.09 gears. Im trying to find an RX series car right now to rob a new chunk from. The RX cars have 3.50 gears from what I'm told. I have 88-98 GM 1/2 ton drop spindles with '98 C2500 "light duty" six lug rotors up front.
Very interesting rear suspension. With the frame Z'd like that, will the truck lay running board on the ground with 20" wheels? How well does that rear suspension handle axle wrap and side movement? Did you make all the rear suspension parts?
Old 10-22-2013, 10:56 PM   #30
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
WOW, made quick work of that. Nice job.
--Josh
Old 10-23-2013, 08:18 AM   #31
ghettoluxury
ghettoluxury's Avatar
I see you used 88-98 C10 drop spindles. Are the control arms also for 88-98 C10?
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-08-2013, 01:42 AM   #32
selfbuiltrods
The control arms are from an Ebay mustang II kit. I machined balljoint cups for an 88-98 lower balljoint and fitted them to the lower arms. As for the uppers, I adapted an 88-98 upper ball joint. Ill sanp a few up close pics for you tomorrow.
Old 12-08-2013, 11:49 PM   #33
selfbuiltrods
Sorry I've not updated my thread lately. Not much has been done, work has been busy, but over the course of time some things have been done.
Got the motor settled in...
All the air ride is buttoned up...
Swapped over to 97 C1500 front spindles and rear axle...
Narrowing the rear housing...
Added front shocks...
This weekend I re-did my upper control arms to accept a bolt in ball joint that actually fit the spindle. Got a little more lift out of the front this way...
Now I'm currently cutting the cab apart to replace all the rust. Once I get the body ready, Ill finish the chassis. Steering, brakes, fuel, electrical, etc. Still gotta build that wiring harness for the motor, but hopefully I'll be driving this dude after tax time lol.
