#26 |
Re: what makes it bump between gear selections
#27 | |
The Older Generation
![]() LockDoc
#28 |
Great info here.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#29 |
laying low
![]() Join Date: Mar 2001
We can see by your pic someone in the truck's past cobbled a shifter linkage together by cutting and welding the bracket at the trans end. He didn't have all the correct pieces so he made do with what he had. Some parts have been lost over the past 40 yrs.
Tim posted the correct pieces in that diagram to make it all work smoothly. They are available. The main drawback to the straight aftermarket linkage is it doesn't manage engine torque effect with that straight setup. As the engine/tranny torques over it pushes the linkage upward. The OE linkage addresses engine /trans movement. It is not a problem under normal driving conditions but with this aftermarket linkage you might see the shift lever in the cab move upward under hard acceleration or in offroading situations where the frame and cab twist a bit.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
