#26 |
Don't blame the messenger
Re: Aftermarket steering column
Yes, A very good read indeed. Time to go shopping.
On the Level Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525 "Some drink from the fountain of knowledge while others just gargle." |
#27 |
![]() Join Date: Mar 2013
I was just looking at those CCP units too, wondering how they were so much cheaper then others, now I know why.What a bunch of scum bags.
#28 |
I just emailed CPP. DO the same.
#29 |
I read a good portion of the safety report and now I am pissed that companies are selling this JUNK!!! It makes me doubt the quality of anything CPP sells.If I replace my factory tilt I will use Ididit or Flaming River. USA!!!!!!!!!!!!!
David ![]() |
#30 |
Moderator
![]() Join Date: May 2007
CPP also carries flaming river and Ididit columns...you have a choice. Given the choice it's obvious most people go for the cheapest option though
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#31 |
Here are a few words
1.IDIDIT STEERING COLUMNS 2.USA MADE 100% 3.GM INTERNAL MADE PARTS 100% 4.LIFETIME WARRANTY FROM IDIDIT EASY DECISION HERE |
#32 |
Bought a truck with CPP tilt column already installed. Shifting moves the column all around and the indicator doesn't line up, 4speed auto. Shift knob is cracked at bottom and the pin that hold the shift lever in is loose. Does not work well with shift detents. Installed a 94 chevy wheel and the horn stuff doesn't work with newer wheels.
Probably replace after I fix all the other stuff. |
