Old 06-03-2013, 12:11 PM   #26
94cummins12v
94cummins12v's Avatar
Re: 1959 gmc 450
Well I know the title and I'd tage in the glove box say 1959 I'd just like to figure out what engine the damn thing has in ita ran a new 1/4" fuel line from the fuel pump to one of the saddle tanks and put an inline filter in fires right up untill the filter runs dry its almost like the filter isn't filling fast enough for what its burning wonder if I should do a new draw straw
04 F350 charcoal and chrome, 500hp 6.0l powerstroke
04 GMC Yukon 5.3l with some goodies
1977 Chevy k30 lifted on 37s with sbc 400 and 4 speed
1959 GMC 455v with 10.00-20 tires and 16' dump bed
94cummins12v is offline   Reply With Quote
Old 06-04-2013, 11:55 PM   #27
94cummins12v
Re: 1959 gmc 450
Well I dug a little deeper truck does have a 302 inline six in it
Old 06-07-2013, 12:13 PM   #28
94cummins12v
Re: 1959 gmc 450
So according to the vin and I'd rage its a 1959 GMC 455 v with a 302 I6, started pulling wheels and getting tires mounted it came with 9.00-20 all around and I'm gunna run 10.00-20 in the rear and 9.00-20 in the front
Old 10-06-2014, 07:57 PM   #29
94cummins12v
Re: 1959 gmc 450
Curiosity does anyone know what transmission came in these trucks its a 5 speed or a 4 speed with granny low I'm wanting to take the 302 I6 out and throw a 350 or SBC 400 in it
Old 10-06-2014, 08:26 PM   #30
lv2tri2
Re: 1959 gmc 450
Taking that motor out would be shame, IMHO
lv2tri2 is offline   Reply With Quote
Old 10-06-2014, 08:27 PM   #31
lv2tri2
Unhappy Re: 1959 gmc 450
sorry about the 2nd entry
Old 10-06-2014, 09:47 PM   #32
OrrieG
OrrieG's Avatar
Re: 1959 gmc 450
Look at the link in my signature. Scroll down to the year index tab, choose year then look for the tranny section. Pretty sure 4 speed was all there was, with two speed rear end to split the gearing for heavy loads.
OrrieG is offline   Reply With Quote
Old 10-07-2014, 03:54 PM   #33
94cummins12v
Re: 1959 gmc 450
The only reason I'm wanting to take it out is because its blown and SBC are Easyer to come across
Old 10-08-2014, 12:43 PM   #34
_Ogre
_Ogre's Avatar
Re: 1959 gmc 450
found a 59 450 brochure on ebay
possibley: 5 speed dirrect or 5 speed od with 2 speed rearend; or 6 speed with single speed rearend
shop air compressor timer
Old 10-08-2014, 12:58 PM   #35
_Ogre
_Ogre's Avatar
Re: 1959 gmc 450
your big truck needs a biggg gmc motor: i vote a gmc 702 twin six
Old 10-08-2014, 03:02 PM   #36
OrrieG
OrrieG's Avatar
Re: 1959 gmc 450
A couple of months ago I went to one of the wrecking yards and they had one sitting in the parking lot. Looks like it may have come off of an irrigation pump, they were sold for that use (like lots of early Hemi's). Top rpm is like 2500, but they have a ton of torque and will run all day. I will post more pics in a separate thread.
Old 10-08-2014, 03:58 PM   #37
Highsider
Highsider's Avatar
Re: 1959 gmc 450
I knew nothing about the 702 Twin-Six existing.
Is it a 12-cylinder?
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 10-09-2014, 02:14 PM   #38
94cummins12v
Re: 1959 gmc 450
The truck is defiantly in fact either a 5 speed or a 4 speed plus overdrive. The reason I'm asking is what itbwould take to bolt up to a SBC 350 or 400 or do I just say screw it and throw a sm465 4speed in its place when I do the SBC conversion
Old 10-09-2014, 04:11 PM   #39
_Ogre
_Ogre's Avatar
Re: 1959 gmc 450
unless you can post/google trans numbers
once you have it out rotate the front shaft 10 times and count the tail shaft rotations to see if it's 5 spd direct or 5 spd od
most gmc/chevy transmissions of that period had the 4 bolt pattern to any bell housing
does the truck have a 2 speed rearend?
i had a 56 chevy school bus/camper with a 454 truck motor, 4 speed granny trans and 2 speed rearend
the rearend was vacuum operated as was the little gearbox behind the speedo cluster for shifting the speedo
it would cruise 80 all day and got 9 mpg, not bad for the boat it was
Old 10-10-2014, 06:51 PM   #40
94cummins12v
Re: 1959 gmc 450
It does have a 2 speed rear end it has an electric control box on it to shift from high to low
Old 10-11-2014, 04:15 PM   #41
_Ogre
_Ogre's Avatar
Re: 1959 gmc 450
those new fangled electronics for 59
Old 10-12-2014, 08:31 AM   #42
1project2many
Re: 1959 gmc 450
Somebody spent some money on this truck when it was new! The vintage racecar / land speed guys love getting those old 302's. High torque when new and could make surprising levels of power in the right hands.
http://www.jalopyjournal.com/forum/t...mc-302.586167/
GMC's engineers were usually smart enough to build the truck to fit the engine so keep in mind the 302's stock numbers were 160 hp @3800 and 268 ft-lbs @1600. A 350 would make more power and torque but it might end up spending much time well below its efficiency range without a cam change. There are some really good low end cams out there. The HT383 cam is great for roller engines and is cheap, too. Crane sells a flat tappet cam for "brute low end torque" that's also available under a GM part number.
Ya know, I've just gotta ask with that username, why not swap to diesel? A SBC would be a practical but "Ho-hum" swap but a 4BT would provide plenty of power and torque in the same RPM range as that old Jimmy. A 6-71 would out pull anything SBC that doesn't have forced induction.
1project2many is offline   Reply With Quote
Old 10-14-2014, 04:46 PM   #43
94cummins12v
Re: 1959 gmc 450
I won't do a Cummins conversion in anything ever again I did a twin turbo Cummins 12v in a 96 f350 crew cab long bed and got it featured in a magazine. This dump truck I won't invest that type of money with all the pin heads in this country driving up 4bt and 6bt prices
Old 10-14-2014, 05:08 PM   #44
66Submarine
66Submarine's Avatar
Re: 1959 gmc 450
LOL!
What about a 454? Those seem to be available cheap these days with the diesel/LS craze. I just picked up a motorhome for $700 with one that runs like a swiss watch to go into one of my trucks.
I think most of the 5 speed HD stuff uses an SAE bellhousing, so you'd need to get one off another HD truck with the right pattern (AFAIK).
I'll also second that the old 2-stroke stuff is neat to see.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-16-2014, 08:54 PM   #45
94cummins12v
Re: 1959 gmc 450
I'd consider a 454 if I could get one for a deal I can find late 70s early 80s 3/4 ton all day long for a grand keep the engine and part the rest out
