#26 |
Re: wheel and tire combo
do a you tube search for 1956 Jack Daniels Truck. You'll see a couple videos from PTC Cars. I believe you may get a few idea from that one.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#27 |
#28 |
Hey, I like it. I know someone has said they don't like "posers"; I think I get what is meant by that. But I like and respect anything done to ones tastes...chopped, stock, modified, gasser look, old beater, period correct, or maybe something else....so I think the so called Jack Daniels truck is good. I wonder what they are asking. The truck I have is in much better shape than that one...
#29 |
Great looking truck!!
#30 |
if I remember correctly, that truck was fetching $12,000 on their website last year
#31 |
Here is some info that my have some good points, 23 videos!!
Wheel Alignment Tips for Custom Cars : How to Adjust the Control Arm I found it on You Tube
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#32 | |
![]() Join Date: Jun 2012
#33 |
#34 |
not the best pictures, but updated with satin powder coat on wheels and lowered back end.
#35 |
I like the change. The stance looks much better.
#36 |
Looks much better!
How did you lower the rear end?
#37 |
I will add some better pictures soon. Thanks for the comment. As for the rear end, I removed 3 of the six rear leafs and put on a set of Monroe Air Shocks. I can lower it more but need to roll the inner fender lip a little bit. However with the air shocks, the thing rides great......
#38 |
ok, now a few better pictures outside. Still considering center hub caps or bullet caps....maybe stays like this of with trim rings....not sure yet....I like if for now.
#39 |
Certified Car Nut
vjjack04,
That truck is looking really nice. Good job man, good job. |
#40 |
Nice work, I like the stance and the wheels sit nice in the fenders. What wheel/tire combo did you with in the front and rear? I read through the thread but must have missed it somewhere.
55' 3100 big window |
#41 |
Man, what a difference in attitude. I personally would go with spider caps to set it off and give it that muscle truck look. Either way, the change in wheels and height have made all the difference in this truck already
#42 |
I like it! I do agree about the hub caps. Tim's idea sounds good or maybe the small police caps. just something to break it up a little.
#43 |
I was referring to the wheel and tire size that is..
#44 |
Did you get your front end straightened out, are you driving your truck?
#45 |
The truck has corvette like rally wheels from summit racing (pretty cheap) 7x15 on the front (with p255 60s) and on the real same rally wheels except 8x15 and has p275 60s. Back spacing is 4.25 on both the front and back. I did have to bend the rear fender lips in to make the rear tires fit. If I could have waited for 4.50 back spacing, it would have been perfect. Still, they fit with no rubbing (since fender lip has been rolled in). By the way the wheels come silver but I had them satin powder coated with a 20% shine (above flat).
#46 | |
I am driving it some (around town-Sierra Vista). I have yet to see your front end guy for the final adjustment. It is relatively close from/for "eye balling it". It actually drives and tracks really well, but need it adjusted so I don't eat the front tires off. Now that it is pretty close, I will get it done (final front end adjustment) soon....I do believe that the upper A arms will need to be a 1/2 shorter though....we'll see.... |
#47 | |
How is your truck working for you !
