06-13-2013, 12:40 AM | #26 |
Re: I think my truck might be a numbers matching
This is right out of the 60-66 Chevy truck assembly manual so I tend to believe it more than a random engine site.
06-13-2013, 12:45 AM | #27 |
So what your saying is all the trucks made in 65 with a 283 only has a WE or WA and that's it???
Posted via Mobile Device |
06-13-2013, 12:57 AM | #28 |
Yes, ask the question on the board of anyone who has the original painted grey 283 motor and it will be coded WE or WA. If it is orange it has been probably rebuilt, if it is grey it is original.
06-13-2013, 01:04 AM | #29 |
This was taken out of a one owner low mile truck, original grey color and is a 65 motor.
06-13-2013, 01:08 AM | #30 |
06-13-2013, 08:29 AM | #31 |
Well here it says 195 HP doesn't it seem weird my truck is a 65 and the block matches a 65
06-13-2013, 09:03 AM | #32 |
"Well here it says 195 HP doesn't it seem weird my truck is a 65 and the block matches a 65"
No because if your truck was assembled in the middle or near the end of the 65 run, the date should probably match. Do you know what tranny you have yet? |
06-13-2013, 09:06 AM | #33 |
Did you post the casting number thats at the back of the block on the drivers side? I might have missed that.
06-13-2013, 09:09 AM | #34 |
06-13-2013, 09:25 AM | #35 |
06-13-2013, 09:27 AM | #36 | |
06-13-2013, 09:28 AM | #37 |
On that chart scroll to the right and you will see full size meaning impala , belair etc, if it was out of a truck it would have C10, 20 etc there. Look at all the WA to WZ coded blocks and you will see that they were all for trucks.
06-13-2013, 09:49 AM | #38 | |
06-13-2013, 01:20 PM | #39 |
you have been given some pretty good info. there are only a couple of ways that it can go. did your truck orig have a p/glide or a m/trans. the truck is 50 years old so it could have gone thru some eng changes over the years
ron |
06-13-2013, 06:18 PM | #40 |
Just thought I'd throw in my 2 cents here. LT1 Burb has it right. Not sure where you found that suffix at. But I will back LT1 Burb 100%. The proof is in the GM books.
06-13-2013, 06:44 PM | #41 |
No matter who u back or what you believe do you find it ironic the motor is out of a 65 and the truck is a 65
06-13-2013, 07:28 PM | #42 | |
ron |
06-14-2013, 12:07 PM | #43 |
there has been talk about this over the years, that on the assembly line they might of substituted a car eng instead of the truck eng (really the same in base form). ran out of the correct stamped eng maybe? ck the date code on the back of the block. it should be before the build date of the truck (if you know that) I would thank nobody would go through the trouble to find the correct date code unless it was totally restored. some deck the block and re-stamp the #'s on a correct date code also. ease up on the people giving info----------
1961 chevy K10 my build is------------61K10 build |
06-14-2013, 03:29 PM | #44 |
Mine was until I got a hold of it....
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
06-15-2013, 12:35 PM | #45 | |
06-15-2013, 01:16 PM | #46 |
You find the date code in this link.
http://www.nastyz28.com/sbchevy/sblock.php |
06-15-2013, 01:59 PM | #47 | |
06-15-2013, 02:06 PM | #48 |
Yes you did but if you look in the link it tells you where to find the casting date!!
