06-18-2013, 11:08 AM | #26 |
Re: another 1972 one ton
Also interested in the front outer panel for the marker lights.
06-18-2013, 12:25 PM | #27 |
Also interested in the front outer roof panel for the marker pads if not rotted.
06-18-2013, 04:44 PM | #28 |
need to see the other side to determine if it has the taper bearing or not. does the yoke seem good and tight with no play? thanks.
87 3/4 Burb 454 49 Chev Fleetline Deluxe |
06-18-2013, 08:46 PM | #29 |
sorry the truck is already at the crush yard. i have edited the original post for the parts that are left.
496bb- pics, the gears have a little wear, you can move the ring gear about 1/8" or less against the pinion |
07-09-2013, 09:10 PM | #30 |
do you still have the rear-end? need a 410 open for 69 c-30
07-09-2013, 09:47 PM | #31 |
yes I do.
07-10-2013, 08:48 PM | #32 |
how much picked up there and do you know for if the same as my 69 c30??
07-11-2013, 05:52 AM | #33 |
bcrouch- it should be the same as long as the rear end under your truck has a removable chunk with a round cover on it. I`ll take $125 for it if you pick it up
07-17-2013, 11:38 PM | #34 |
Is the front swaybar and brackets still available? price shipped to 70769? thanks
09-28-2013, 05:52 PM | #35 |
I might be a little late, but do you still have the custom 30 emblems?
09-28-2013, 06:09 PM | #36 |
Is there any chance of it having a PTO output?
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
09-28-2013, 06:47 PM | #37 |
lake man- i still have the custom 30 emblems. $30 plus shipping.
tlcrz1972- no pto . |
09-28-2013, 07:04 PM | #38 |
What is the condition of the grille emblem?
09-28-2013, 07:58 PM | #39 |
I am interested in several items.
1. the grill emblem 2. the control arms and their shafts( if the steel bushings havent been blown out and ovaled the control arm holes) 3. the front spindles My zipcode is 20748, if i think of anything else I'll repost |
09-28-2013, 08:00 PM | #40 |
Did this truck have power steering?
09-29-2013, 08:07 AM | #41 |
I'll take those emblems. PM me the details.Thanks
04-23-2014, 01:52 AM | #42 |
Do you still have this? Interested in the frame.
04-23-2014, 07:39 AM | #43 |
Do you have the keys for the ign switch and door locks? If so how much to 27501. Thanks,Russ
04-23-2014, 08:19 AM | #44 |
Engine stands?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
04-23-2014, 12:35 PM | #45 |
Russ33 -$40 plus shipping if i still have them. it will be saturday before i can check. you might want to check with member locdoc. i`ve seen him sell a few sets on here.
MrGoodpliers - these are gone but i know where a set including the clamshells and mounts are for $200 plus shipping. |
04-23-2014, 02:44 PM | #46 |
No hurry,let me know Saturday also if ya have the keys for them. I will take them if ya still have them with the keys. Thanks,Russ.
08-29-2014, 10:22 AM | #47 |
so is the outer roof panel gone? I was quickly browsing and didn't see if it was gone or not, would be interested if it is still available
08-29-2014, 03:41 PM | #48 |
Interested in the custom 30 emblems. What condition are they in? Can you get a close up picture? thanks
08-29-2014, 04:42 PM | #49 |
It didn't happen to have had a vacuum gauge cluster that you saved and its associated hard line?
08-29-2014, 08:53 PM | #50 |
Feller- this truck is gone. check with board member uncle, I think he had a cab with roof lights
Douglas- I think the emblems were sold , but I might have another pair. will check tomorrow. kaphillips - I think I have a vacuum cluster , will check tomorrow |
