Old 06-19-2013, 10:02 AM   #26
mknittle
mknittle's Avatar
Re: Got the truck down street, now questions
Originally Posted by Denee007 View Post
I took the truck (I'll come up with a name for it someday) around the block yesterday evening. I'm getting my courage up to drive it to the muffler shop this morning. When I got it going faster, say 25mph, it seemed to steer fine, or at least hold a steady course and not be so squirrely like at slow speed. The muffler shop is about 3 miles from here and I'm really dreading the drive. I think it's mainly the sound resonating inside the cab, even with ear plugs I can't hear myself think! OH, and I messed around with the adjustable proportioning valve, seemed to make a difference on how it stops. There's no real weight on the back right now and with a harder press on the brakes, the rears start to squeal (rears braking first). So, I read that to test the PV(proportioning valve), one should test on a wet road or loose gravel road, but I don't have that option, eh.
Hopefully traffic isn't too bad~
I'll be back with a report on my exhaust on my build site
wish me luck!
dne'
How did you set your caster and toe on your axle?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-19-2013, 12:53 PM   #27
Denee007
Denee007's Avatar
Well, my caster was set by 6 degree shims supplied by Sid@dropped axles, but funny you should mention Toe! I set it by measuring tape while up in the air(on lift) at about 1/8" toe in. I told myself a while back that I was going to have to set it better than with a tape measure! It's our anniversary today, so the truck is on hold today, but I did get the exhaust on this morning, and it's WONDERFUL!
I do have a home made toe in gauge that I need to pull out and will check that tomorrow, probably has something to do with why it's wondering at the slow speed?
dne'
ps: thanks for bringing it up!!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 06-19-2013, 01:05 PM   #28
dubie
dubie's Avatar
ooooooh now we need some exhaust videos, but not until your anniversary is over.
Enjoy your day together and Happy Anniversary eh
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-20-2013, 01:10 AM   #29
solidaxel
solidaxel's Avatar
I have fount the rear brakes to be too loose which makes a big difference in how they feel.
The rear brakes seem to work best when they are tight (can not move wheel)AND THEN BACK OFF 11 CLICKS wheel should have a bit of drag.
Front discs need more miles to "BED" them in.
I have found the adjustable PV to work best at 2 1/2 turns out on the 55.
Congrats on a lot of hard work
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-20-2013, 07:57 AM   #30
buggy5872
buggy5872's Avatar
Denee you might want to try lowering the pressure comming out of the power steering pump. you can take the control vave apart and add some washers to knock down the pressure. I adjust the pressure in the pumps to give it more road feel. You could also buy one of these but I use washers because they are cheap. http://www.ebay.com/itm/New-Mustang-...3f8913&vxp=mtr It makes a huge difference on how the steering feels and reacts. I am running a camaro subframe in my 59 and still knocked down the pressure for a better steering feel.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 06-20-2013, 09:20 AM   #31
Denee007
Denee007's Avatar
Solidaxle, I did what you said, I adjusted the rear brakes and backed off a bit. When coming home from the muffler shop, I did notice the brakes seem to be stopping much better! Like you said, "Bed them in!" Thanks!
Buggy, so that will reduce the pressure going to the steering gear? I think for me, I'd just soon buy the part you so nicely posted If I'm going to have power steering fluid go all over the place, I only would want to do this once! lol Thank you for that link!!!
dne'
Old 06-20-2013, 10:21 AM   #32
buggy5872
buggy5872's Avatar
The one in the link would probly work out best for you. It takes a couple trys with the washer method. Its been so long I can not remember how many washers I used to give you a starting point. I believe I did it back in 1999....
Big Bertha Build
Old 06-20-2013, 12:05 PM   #33
Denee007
Denee007's Avatar
Thanks Buggy! I just forget what kind of end went into my power steering pump! The link mentioned an adapter in case of an o-ring or other fitting. I'll have to remove the fitting to see what it is. Not looking forward to that, However, I set the Toe on my truck, it was toed out about 3/4", maybe that may have caused the wandering phenomenon~ I doubt it, but if setting the Toe helps, that would be great!
Old 06-20-2013, 06:25 PM   #34
butchp
I would think you should set the tow with the truck setting on it's weight after you roll it back and forth a few times. If this is what you did pardon me.
butchp is offline   Reply With Quote
Old 06-20-2013, 08:18 PM   #35
G&R's57GMC
G&R's57GMC's Avatar
That would be the procedure for an IFS , but not necessary for a beam axle.
The point of rolling back and forth is to allow the I. F. suspension to settle to its ride height and then the toe would come to its natural state.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 06-20-2013, 08:20 PM   #36
G&R's57GMC
G&R's57GMC's Avatar
Congrats Dne' !
How does the rear end sound ?
Glen & Jane's Rides
Old 06-20-2013, 09:04 PM   #37
Denee007
Denee007's Avatar
Well, I've only driven it, say 30 mph, but all it quiet right now. When I had it up on jackstands, I let the engine run and had the truck in drive~ kind of seating it in? I read this somewhere. There were a few drops of grease coming from where the nut holds the yoke on, not the actual seal. I think it may be leaking from the spine? I guess I need to pull the driveshaft back off and the big nut and figure something out. I hate to take the yoke back off~ it went on kind of difficult. The old one came off really easy. Overall, I think the rear end may work out after all(I hope I hope!).
dne'
Originally Posted by G&R's57GMC View Post
Congrats Dne' !
Old 06-21-2013, 01:30 AM   #38
OrrieG
OrrieG's Avatar
is the molatov gas cap in the videos just there to fill? little bump, little splash of gas on thr shop towel, little spark, big problem.
OrrieG is offline   Reply With Quote
Old 06-21-2013, 08:15 AM   #39
Denee007
Denee007's Avatar
It was just to fill the tank, I have a galvanized pipe over it when I pull the funnel out. I am having problems finding a filler neck however. I have no idea why they put only a 1 1/2" inlet to connect to! I ordered a flip up door/trap door (whatever it's called) from Speedway, then have to come up with a permanent idea for the tank fill.
Old 06-21-2013, 06:50 PM   #40
itstheshu
Look at fill caps from a boat. They use 1 1/2 hose as well.
itstheshu is offline   Reply With Quote
Old 06-21-2013, 07:29 PM   #41
OrrieG
OrrieG's Avatar
Find a place that makes up industrial hoses. they will have it. Also lots of 1.5 boat fuel hose on Ebay and other boat places. Usually runs about $1 per inch with 12 minimum. Do not use radiator or other non fuel rated hose. Also look at motorcycle pop up type hose bungs and caps.
Old 06-21-2013, 07:37 PM   #42
roger55
roger55's Avatar
GATES Part # 23964
It's a 3 ft. long piece of 1 1/2" gas filler hose. It's what I used on my truck.
Here's a closeout price:
I bought mine here for that price.
http://www.afec-az.com/detail.cfm?part=1133346
roger55 is offline   Reply With Quote
Old 06-21-2013, 09:44 PM   #43
itstheshu
O'reilly auto parts stocks it. Its just finding an employee that knows what it is.
Old 06-21-2013, 10:02 PM   #44
Daze57
Daze57's Avatar
Boy u ain't kiddin ^
Daze57 is offline   Reply With Quote
Old 06-21-2013, 11:03 PM   #45
roger55
roger55's Avatar
The one I supplied the link to is $13.47 free shipping and no tax for a 3 ft hose.
O'Reilly's gets $15.99 per ft or $47.97 plus tax for a 3 ft. hose.
It's about $27 plus shipping on Rock Auto.
Old 06-21-2013, 11:46 PM   #46
srengr
srengr's Avatar
Denee,
Southwest Alignment on Richmond can handle finishing your aligment for you. The owner knows his way around a straight axle. He does a lot of old trucks for the used car dealers along Richmond. Did my '59 TF as well as my '68 Camaro.
Thanks,
srengr
1959 3100-- Mild Resto-mod, 327 small block, TH350
srengr is offline   Reply With Quote
Old 06-22-2013, 12:09 AM   #47
OrrieG
OrrieG's Avatar
Make sure it is fuel rated hose. When I was searching for mine, I found one at O.reilllys that the website says it for fuel but when you look at the packaging it is not. The real rated fuel hose they showed me was $16 per foot, min 1 foot.
Old 06-22-2013, 12:25 AM   #48
roger55
roger55's Avatar
The Gates #23964 is specifically a fuel filler neck hose.
Rock Auto has it for $9 per foot.
That other link I provided is selling it for half price as a close out. $13.47 for a 3 foot length. I bought one. It's the real deal.
