Old 07-01-2013, 09:12 PM   #26
superwade57
Re: Interchangeable parts
Yup that's a crate motor or at least its valve covers
superwade57 is offline   Reply With Quote
Old 07-01-2013, 09:16 PM   #27
Riley012
Thanks, the truck was hit in the front right corner and the right hub is froze up. So I am guessing it was running ok up to that point. I really just bought it for the body parts but I was hoping I could sell any remaining parts. Thanks again
Riley012 is offline   Reply With Quote
Old 07-01-2013, 10:05 PM   #28
motornut
78K & 79C Jimmys
motornut's Avatar
Originally Posted by Riley012 View Post
Is it ok to keep the 82 steering, so I don't have to worry about the wiper switch and how about the cruise control. Thanks
the high/low beam switch moved too,watch for that
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-01-2013, 10:15 PM   #29
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Yep, looks like a crate motor to me. They do have good heads on them, and they are not a bad motor, just not a power house.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 07-10-2013, 08:58 AM   #30
Riley012
I am trying to sell the motor and tranny.
Old 07-10-2013, 10:42 AM   #31
SamsAutoParts73-87
If the motor runs you won't have a problem selling it, but Crate motors are hard to sell as a "CORE". The guy I sell my blocks to does not like to buy the crate motor blocks, only the heads. If you can find a buyer that is just looking for a replacement motor, then your golden.
-Sam
Old 07-16-2013, 07:43 AM   #32
Riley012
What is the easiest way to remove the cab? Thanks
Old 07-26-2013, 08:59 AM   #33
Riley012
Has anyone used a sawzall to cut through the cab bolts. Thanks
Old 07-26-2013, 09:15 AM   #34
SamsAutoParts73-87
I have used a sawzall a couple of times, I usually only do it if I'm junking the cab, and I don't feel like dragging out my torch. If I'm trying to save the cab I just grind the head of the bolt off. Some times all four of the bolts come out with a socket, but it is not very often.
-Sam
Old 07-26-2013, 09:11 PM   #35
Riley012
I broke one off, one came out, one rounded and the last one felt like it was going to break so I stopped and sprayed with some more release agent.
Old 08-13-2013, 08:22 AM   #36
Riley012
Just got out all 8 bolts holding the box on, tried socket that did not go well, used a grinder and that worked great, removed tail light lenses and screws holding gas necks in on both tanks, can anyone think of anything else I should be concerned with. I thought I would work on the box first hoping it would give me more room to work on removing the cab.
Old 08-13-2013, 08:30 AM   #37
SamsAutoParts73-87
ground straps, and the differential breather hose, bolted to the bottom of the bed floor
-Sam
Old 08-15-2013, 05:54 PM   #38
Riley012
I took the seat and carpeting out of the red truck today and this is what I found. Looks like I will be replacing both floor panels , rockers and cab corners. This will be my first attempt at this. Any suggestions.
Old 09-06-2013, 08:55 AM   #39
Riley012
Angry Re: Interchangeable parts
Found out this past weekend that the 350 motor was froze, tried spraying release agent in the cylinders. Does anyone have any advise. Thanks
Old 09-14-2013, 10:17 AM   #40
Riley012
Can anyone tell me an easy way to replace leaf spring bushings. Thanks
Old 09-14-2013, 10:44 AM   #41
Originally Posted by hatzie View Post
Is the 85 column a Tilt or has some other desirable feature? Or is the 82 cab beat to death??
In 83 GM moved the wiper switch to the Turnsignal stalk. Marrying an 83 or later column to the 82 cab harness would be an adventure but not impossible... given time, patience, and a full set of wiring diagrams for both years.
If you're swapping the cabs just keep the 85 cab harness and column. You can re-pin the 82 engine compartment bulkhead plugs to match the pinouts of the 85 cab socket. Most of them will probably match already.
I assume you'll be getting a current title to go with the VIN plate riveted to the 85 cab... That's the only real gotcha on a cab swap.
As he said mostly little things, but 84 was the year that the wipers changed from the dash to the turn signal stalk on the column.
Placement of the front turn signals differ also. 82 turn signals are in the bumper, 83 and newer went in various places of the grill.
