07-12-2013, 11:32 AM | #26 |
Re: Need help! Boss 338 fitment.
Looking to pick up a set of these. Just read that the 14 mm et on the 20 X 8.5 (5.25 BS) rub on the inner fender. Is this the size I need? Wil I get away with a 255/45 tire up front? I've got an ECE 2/4 drop. Might go lower in the future with spindles.
As for the back I understand the 20 X 10 with 2mm et would be the ones to get. It's a '72 rear end. Posted via Mobile Device |
07-13-2013, 02:34 PM | #27 |
ttt
07-13-2013, 06:02 PM | #28 |
I think u will be fine at that ride height, but if you put a set of spindles on, you will def rub, eps since your tire size is taller than mine. If you ever want to go real low, I would et the ones with even more back spacing.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
07-13-2013, 07:56 PM | #29 |
Where are the pics with the new wheels?
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
