06-26-2013, 11:00 PM | #26 |
Re: Is the door jamb pillar vent incorrect in my '70 K10?
67-72 had a small hump where the rear view mirror mounted to, 72 had the hump eliminated as the mirror was glued to the windshield starting that year.
71 K20 64 GMC mud truck |
06-26-2013, 11:12 PM | #27 |
Roadtrip!
If it is slightly raised where the mirror mounts on the roof it is a 71 cab. That was the only year that did that. So if it is there with the vent i would say it is a 71 cab.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-26-2013, 11:39 PM | #28 |
Yes too much stuff is correct, '71 was the only year cab with the raised pad for the mirror.
06-27-2013, 08:31 AM | #29 | |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
06-27-2013, 10:19 AM | #30 |
Oh dang I realized I worded my post completely wrong
06-27-2013, 11:11 PM | #31 |
Roto Reuter thats the name...
Here are some pictures of my mirror mounting. So based on these pictures does this mean it is a '71 cab?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
06-27-2013, 11:28 PM | #32 |
That looks like a '71 cab to me.
06-28-2013, 07:31 AM | #33 |
Carpe manana
There isn't a raised pad for the rear mirror mount so I'd say no it is not a 71 cab.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-28-2013, 07:50 AM | #34 |
Carpe manana
Here's an example of what the pad looks like:
06-28-2013, 10:10 AM | #35 |
Now that I look closer Deadhead is right no raised pad, the reflection is what I was seeing.
06-28-2013, 05:28 PM | #36 |
Oh OK. Now I see what you are referring to. It definitely does NOT have that raised surface. So... it looks like it's a '70 cab with a pillar vent I guess.
06-29-2013, 10:46 AM | #37 |
So if this is not a '71 cab, it must be a '70 cab. Now are there any documented versions of '70 trucks that had the door pillar vents? Anyone know?
06-29-2013, 03:54 PM | #38 | |
Roadtrip!
Do you have a cable or rod for the throttle hookup? Gas pedal attached to the floor?
06-29-2013, 04:48 PM | #39 |
Probably is easy to cut in. I have cable throttle linkage, with gas pedal NOT attached to floor. My '69 has the ball studs on the floor for mounting the gas pedal.
06-29-2013, 11:53 PM | #40 |
Roadtrip!
Interesting... a 70 cab would also have the studs on the floor with a solid rod for the throttle. Possiby a 72 cab? If you have the carpet up, look for any trace there were the 2 studs attached to the floor.
07-01-2013, 10:51 PM | #41 |
Looked and didn't see any signs of ball studs for a 70 gas pedal. Hmm.... Maybe '72 cab. Now I'm puzzled. This is crazy. So someone would have had to replace cab and reinstall VIN with rosette style rivets? What other differences would there be that I could look for?
07-01-2013, 11:00 PM | #42 |
The rosettes are hard, very hard, but not impossible to get. 15-20 years ago they were plentiful.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-01-2013, 11:12 PM | #43 | |
Carpe manana
07-01-2013, 11:27 PM | #44 |
The rosette rivets can be made with a little effort, not that I would, would I.
07-02-2013, 08:52 AM | #45 |
yea looks like you could make them very easily,very SHARP TRUCK BTW..
1964 BBC 402 4x4 |
07-04-2013, 09:42 PM | #46 |
There is no evidence suggesting that the VIN was changed or patch of the pillar installed (at least that I can tell).
09-10-2017, 04:15 PM | #47 | |
Posted via Mobile Device |
09-10-2017, 05:17 PM | #48 |
One of the First
Was there ever a final thought on this, really nice truck though. From my experience, to ID a 72 Cab: the is the vent on door pillar, no raised rear-view mirror pad, dimple/screw under vent window on doors, gas pedal set up / holes are drilled in different location for the older rod acceerator. Last, 1972 had a vented gas tank (vapor canister up front). The gas cap was different on a 1970 than that a 1972. Hope Im not waking this up in a bad way.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
09-10-2017, 05:56 PM | #49 |
Who Changed This?
I believe that new rosettes can be gotten from the CHP, in California. I don't know what NY does, though. I have a friend who rebodied a car, as the original sheet metal was too bad off. He was told by the CHP to bring both cars in to be inspected, along with the proof of ownership, and they would transfer the VIN to the better vehicle. This process has been used by body shops to "back-half" a vehicle that has been rear-ended badly enough to require all that sheet metal be replaced. If that truck was wrecked, (rolled over) it is a known thing to replace the cab and then swap the VIN from the old vehicle. This requires prior permission from law enforcement; otherwise, it is fraud.
09-10-2017, 09:47 PM | #50 | |
