Old 10-19-2017, 08:51 AM   #26
seattle gmc
seattle gmc's Avatar
Re: Anyone use the headlight relay wire harness from LMC
Originally Posted by Irishbleueyes View Post
Sure, my problem was the wires going into the plug on the harness sent from LMC. They were in the wrong location, so I switched them around till it worked. I don't remember which color goes to which tab on the headlight but it was easy to figure out. My lights are pure white and it makes a difference on the road as well. If you can't get it let me know and I will go look at where they go for you.
Thanks for the reply im going to look at it this weekend. Were the wires on the wrong tab on the connector that plugs into the existing wire harness, or was it one of the connectors further down the line that plug into the one of the headlights?
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 10-19-2017, 11:18 AM   #27
Irishbleueyes
Just the connectors at the headlight only
Irishbleueyes is offline   Reply With Quote
Old 11-26-2018, 09:39 PM   #28
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Is there a better brand/kit than LMC?
66 C20 Service Truck:
Old 11-26-2018, 10:15 PM   #29
cwcarpenter98
cwcarpenter98's Avatar
I used the United Pacific harness purchased through Summit Racing. Looked to be a quality product, and it worked great. Made my old sealed beams bright enough that I don't feel the need to upgrade any further at the moment.
Edit: Sorry, just noticed that this is for the 4 lamp one. Not sure what is out there for that, but if United Pacific makes one for that application, I wouldn't hesitate to buy a product from them again.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-26-2018, 11:25 PM   #30
LostMy65
LostMy65's Avatar
Thanks, I'll check it out.
Old 11-27-2018, 12:43 PM   #31
The Rocknrod
Moderator
The Rocknrod's Avatar
Here is a thread that might be helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=397695
That thread is great I built my own harness after reading that.
Old 10-17-2021, 08:27 PM   #32
sKnNyPpY
sKnNyPpY's Avatar
Exclamation Re: Anyone use the headlight relay wire harness from LMC
The green and brown wires at the low beam triple prong plugs need to be switched to the same order as the old plug. Brown goes on top and green on the side. Carefully pry them out with a small flat head screwdriver and switch them on each plug. Thanks to this thread I figured it out.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 10-18-2021, 11:55 AM   #33
pdxhall
pdxhall's Avatar
In my opinion, anything BUT LMC would be better. I bought my relay kit from AAW. It's just the 2 headlight system. I have quit buying from LMC. I had a couple of situations before I learned my lesson. It seems they have no quality control.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
