Old 07-15-2013, 09:47 AM   #26
1966burb
1966burb's Avatar
Re: 66 327 4bbl air cleaner question
My PCV comes out of the back of the carb and runs to the rear of the engine. My exhaust manifolds are drilled for air tubes, but are plugged. I will take some pictures.
1966burb is offline   Reply With Quote
Old 07-15-2013, 03:12 PM   #27
MikeN
MikeN's Avatar
Originally Posted by jayoldschool View Post
Note that the base is for the Rochester 4GC, and it won't fit larger later 4BBLs like Q jets, Holleys, Edelbrock, etc.
This is very important. The correct, original style air cleaner won't work on anything but a 4GC carburetor.
MikeN is offline   Reply With Quote
Old 07-15-2013, 11:53 PM   #28
rustbucket66
Does anyone out there have an air cleaner base for a 4 jet carb that I could buy? I need a base to cut apart and weld to a larger based air cleaner. it is the 50's Cadillac type that I have painted and pinstriped. I want to use that original carb, and also want to use the air cleaner I have. An old base in decent condition would be fine.
rustbucket66 is offline   Reply With Quote
Old 07-16-2013, 10:20 AM   #29
cortcomp
cortcomp's Avatar
I have a 4jet base that came off my truck but its not the correct air cleaner and someone connected a pipe plug to it underneath. Perfect for cutting up. Pm me your email addy and i'll send pics.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-26-2013, 09:38 AM   #30
1966burb
1966burb's Avatar
I was able to pick up a nice restored air cleaner on CL yesterday. Someone did a great job of modifying the base to fit a Q Jet carb. I will need to trade that off for an original base to fit my smaller Rochester carb.
Old 07-26-2013, 09:56 AM   #31
cortcomp
cortcomp's Avatar
Man that's a nice air cleaner too!
Old 07-26-2013, 10:53 AM   #32
1966burb
1966burb's Avatar
The guy said that it was painted at a body shop. You can tell it is not a rattle can job!!
Old 07-26-2013, 01:15 PM   #33
rideblue00
rideblue00's Avatar
1966burb: Have a machine shop turn up an aluminum spacer ring. Then you could keep it and maybe use it on another carb some day. I want to modify mine, but dont want to cut it. Mine needs to be bigger. What size hole do you have? I might be interested in it.
rideblue00 is offline   Reply With Quote
Old 07-26-2013, 01:57 PM   #34
1966burb
1966burb's Avatar
This is how it looks modified for a Q jet.
