Old 08-06-2013, 11:35 PM   #26
Crash_OK
Crash_OK's Avatar
Re: A/C Dash Install slice behind dashpad or drill spotwelds?
Drill out the spot welds and remove the bolts..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 08-08-2013, 09:32 PM   #27
tlcrz1972
tlcrz1972's Avatar
Here you go a few pictures of the speakers, finding ones with grills is getting hard to find. And they need to be as low profile as you can get them. So they miss the top of the instrument cluster and the glove box inner.
Like I said good sound quality, but nothing that'll rattle the bolts out of the truck.
Originally Posted by nitrosport_5 View Post
please do! i love a decent stereo. not into overkill rattle your teeth out, but a nice quality sound with good bass is my thing!
tlcrz1972 is offline   Reply With Quote
Old 09-24-2013, 01:16 AM   #28
nitrosport_5
nitrosport_5's Avatar
well, the dash is in, need to finish up a few welds and clean it up a bit, but it shouldnt be too bad. I kept putting this off, worst part was getting each edge under the dash. i ended up doing the lap weld method. worked great! thanks for the help tlcrz1972!
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 09-27-2013, 10:36 AM   #29
tlcrz1972
tlcrz1972's Avatar
No problem, I don't mind helping a brother out. Lap welding is just easier and your less prone to blowing the metal away if it were butt welded.
And you don;t go through the problem of drilling out spot welds and risking other problems.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
