07-17-2013, 03:30 PM | #26 |
Re: 54 GMC, S10 swap, OM617 diesel
Awesome work. Looking forward to more updates.
Posted via Mobile Device |
07-17-2013, 04:40 PM | #27 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
07-17-2013, 04:56 PM | #28 | |
ax-15 should have no problem with the MB motor, they make similar power to the 4.0. |
07-18-2013, 04:47 PM | #29 |
Is your AX15 adapter a full bellhousing?
07-18-2013, 06:39 PM | #30 |
Ill have pics later, prob gonna put it all together tonight!
07-19-2013, 11:11 AM | #31 |
Well it was really hot and sticky last night so I ended up quitting a little early. Got my flywheel drilled for the adapter, and the exsiting plate off the back of the motor. I pretty much need a jeep starter before I can do much, the side of the pan needs to be ground down for clearance, and I dont wanna get shavings inside the clutch and bellhousing.
Heres the adapter mounted to the engine Flywheel adapter, had to drill out the 6 holes which are the mercedes bolts to mount to the crank. this part has to be ground down for the starter |
07-19-2013, 12:49 PM | #32 |
Interesting! So the adapter kit consists of a bellhousing plate, and a flywheel adapter? And you use a Jeep flywheel, starter, and bellhousing?
07-19-2013, 12:55 PM | #33 |
exactly, its meant to use as much OE jeep equip as possible. The other kits out there (4x4labs) is twice the price, but it includes a custom flywheel, thats for the chevy bellhousing. Then you still gotta buy a clutch, starter, trans etc. I'm into this whole setup for about $500 for everything to run it except the starter which will be free from my brother.
07-19-2013, 06:09 PM | #34 |
Free parts from your brother ?
Brilliant !
Chris '69 C-20 '04 Jeep TJ |
07-19-2013, 07:02 PM | #35 |
You are one hard working man, I really appreciate all the pics. I think you may have started something here. Will be interesting to see if you have inspired anyone to go the route you are. My guess is with out a doubt, yes.
av8tr33337 AKA Bartman Email av8tr33337@yahoo.com Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
07-19-2013, 09:09 PM | #36 | |
My near future plans is to mount the trans, get the starter area fitted up (picked up an old starter tonight for fitment. Probably going to lift the cab off, fit the engine and trans and fab a crossmember. The engine sits pretty high so I'm gona need to tunnel the floor some, at least along the firewall and I think it will be easier to lower the cab down to trim, than try to do it with the cab mounted and engine on the crane. Posted via Mobile Device |
07-19-2013, 11:57 PM | #37 |
Only had a little time to mess around tonight. Started to tackle the starter. Slightly daunting to grind away and make room, lickily its webbed and aluminum.
And apparently Im gonna have to get some paint on the adapter. Rusty finger prints overnight. |
07-20-2013, 02:03 PM | #38 |
That's a lot of grinding! I did not realize the block was aluminum.
The adapter I had on my Jeep was a full bellhousing with a Jeep trans pattern on one side and Chevrolet block pattern on the other. Had a casting for a hydraulic slave cylinder on the outside, worked well.
07-20-2013, 03:08 PM | #39 |
thats not the block, its the 'upper' oil pan. Then theres a lower steel oil pan where the sump actually hangs down. The block is cast.
07-20-2013, 03:40 PM | #40 |
Geez, that shows what I know about Benz motors.
07-20-2013, 05:04 PM | #41 |
cool project. I just sold my 54 gmc. good luck. where in pa are you located. i'm in Pittston between Scranton and wilkesbarre.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
07-20-2013, 09:56 PM | #42 |
nice work on the fabrication
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-20-2013, 10:33 PM | #43 | |
Located in southeast pa. Lancaster/chester co line east of ephrata/new holland. Thanks!! Posted via Mobile Device |
07-20-2013, 10:35 PM | #44 |
Got the pan ground down enough for the starter to clear fine. Actually went a little further than I needed to. Hopefully get the trans and engine all mated up tomorrow and maybe pull the cab back off.
07-21-2013, 09:42 PM | #45 |
Pulled my lower pan off today, where I cut and welded it was leaking in one spot, so I welded thst up and resealed. Took some pics that may be beneficial to anyone doing an OM617 swap in the future.
Here you can see where I modified it to not interfere with tie rod ends. Here is the oil pickup, I searched everywhere to find a pic like this showing location so I knew where I could/couldnt plan to cut the pan before I took it off. View from front. Adapter and flywheel bolted to the engine. No issues there at all, everything lines up nicely. Clutch bolted up. Went with a napa labeled LUK clutch, which is oem for jeep and a good set for my truck. And lastly I stripped it back down to the frame so I can mount the engine and make a crossmember without working around the cab. Posted via Mobile Device Posted via Mobile Device |
07-21-2013, 10:44 PM | #46 |
This is looking awesome. I have to say, a Mercedes turbo-diesel swap is pretty unique. Looks like your making quick progress. Keep it up.
07-22-2013, 12:00 AM | #47 |
Cool build. Thanks for sharing.
07-22-2013, 09:04 PM | #48 |
After a little battle getting it all lined up I got the tranny mated up.
Spent most of the day getting it mounted to the chassis. Of course there were some hiccups. I had to redo one of the mount arms on the engine because it was interferring with the steering, which left one side a little off. So I built up one side and made sure the engine sat level. Figured out all my angles and spent way too long devising a cross member and way to mount the trans. It worked out to be perfectly level and I had already bought a factory jeep mount, only to realize the bracket on the trans itself was gone. So heres what I came up with, and another piece thst adapted the mount to the bottom of the trans. Nothing special really. And finally the money shot! Just by eyeballing it, looks like the shifter is gonna come up in a good spot through the floor. Definately going to be building a trans tunnel on th cab as well. Posted via Mobile Device |
07-25-2013, 09:28 PM | #49 |
Made my cut on the firewall to drop the cab back down over the engine/chassis. My dad came by and helped get everything lined up and we nailed it first cut. Still gotta cut the floor a bit under the seat for the tailcone and driveshaft area but at least the cab bolts back on!!
Getting a little dark so not the best pictures. Posted via Mobile Device Posted via Mobile Device |
07-25-2013, 11:00 PM | #50 |
Cool build, Its gonna be torquey for sure.
My '59 Build Thread |
