Old 07-23-2013, 07:04 PM   #26
LONGHAIR
Re: Rear end swap ????
Right here is exactly why the rule against hi-jacking exists......just sayin'
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-26-2013, 11:07 PM   #27
wraprail
wraprail's Avatar
Originally Posted by 66/87chevy View Post
My 85 c10 is going to have a mild built BB with a th350 behind it.... This is NOT a truck that I will be taking road trips with. With that being said I want this truck to be able to go from 0-100mph as quick as possible. That's why I'm thinking of going with 4.11 gears.
If you were looking to use wrecking yard parts to try and keep costs down you will have better luck finding a lower gear (4.11 or lower) in a ford 9inch. I see ford broncos all the time at pic-a-part and some do have lower gears. Easy to pull out ect. I have never seen a gm truck with lower than a 3.73 at the wrecking yard. Not saying they aint out there, just there are alot more fords.
Originally Posted by manimal View Post
The ONLY advantages a 9" has(other than pinion strength) over a GM rear axle is you can change gear ratios VERY quickly.(1hr if you're slow). Have your highway gears in one chunk,and your street/racing gears in another. simple as that.
How about no need for C-Clip Eliminators with a 9" (the axles stay in the housing)
The center of the housing is made of steel. (You can weld brackets)
Factory disc brakes with an e brake.
wraprail is offline   Reply With Quote
Old 07-27-2013, 09:22 AM   #28
manimal
manimal's Avatar
C-clip eliminators can be added to a 12blt/10blt. What brackets are you putting on a 9" that cannot be put on a GM axle? You got me on the disc brakes.
If you are making serious HP and drag racing,Off Road racing or circle track racing,then I would agree with a 9",otherwise,no.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-27-2013, 10:43 AM   #29
wraprail
wraprail's Avatar
What brackets are you putting on a 9" that cannot be put on a GM axle?.
Old 07-27-2013, 05:14 PM   #30
manimal
manimal's Avatar
not everyone "LINK" their trucks.
I'm all for form/function if it is needed for the circumstance,but for "most" it is not necessary.
-Lance
Old 07-27-2013, 09:59 PM   #31
INSIDIOUS '86
INSIDIOUS '86's Avatar
Depending on tire size 100mph may be all you get too haha. My 3:73s with 26" tires gets me to 115mph at 6krpm. A c clip eliminator and 30 spline axles with a t/a bearing girdle and differential of choice will handle 600hp reliably and when the tubes are welded do fine under the trans take and 700hp turbo gnx cars nice thing is the 8.5 ten can do alot and it's already under almost every truck.
Want to get to 100 really quick gears -weight+hp makes that happen quick haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
