Old 07-21-2013, 07:04 PM   #26
Sodell
Sodell's Avatar
Re: Dropping on a very very small budget?
BTW, you could probably fund this by selling your steering wheel to "a good man"
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 07-21-2013, 11:14 PM   #27
frog210
yup buy a used one for now like a 100, then use the rest for the drop my .02
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 07-22-2013, 08:33 PM   #28
MWS1994
MWS1994's Avatar
On a different topic, I need a bed trim piece (as you can see in the pictures). I was wondering if this is the right one: http://www.ebay.com/itm/Rear-Lower-B...b54bee&vxp=mtr
MWS1994 is offline   Reply With Quote
Old 07-24-2013, 08:24 PM   #29
MWS1994
MWS1994's Avatar
So I found this. Is it something that would work with mine?
http://www.airbagit.com/1973-1991-CH...li-che-20f.htm
Old 07-24-2013, 08:33 PM   #30
2ndstoryslam
2ndstoryslam's Avatar
Cutting one coil wrap in front. Re-Alignment. New shorter shocks as well. Rear: Remove box and move front spring mount up accordingly. Drill holes for grade #8 bolts. Trim leftover mount that protrudes above frame rail. You will likely need a shorter shock for the rear. The old truck likely needed new shocks anyway, right? If fab work is not in the cards, buying the parts ($) will be. If you smoke and or drink, go cold turkey for while to pay for the goodies. Every gain demands a sacrifice.
2ndstoryslam is offline   Reply With Quote
Old 07-24-2013, 08:36 PM   #31
MWS1994
MWS1994's Avatar
I'm thinking about doing some fab work if needed.
BTW, I'm 19 so definitely no drinking or smoking is involved and it will never be.
Old 07-24-2013, 09:04 PM   #32
tinydb84
tinydb84's Avatar
Everyone will say no based on the brand. Go take a pick of your axle saddles and post it. If it is like my C20 they only make weld in kits. Can you weld?
David
Instagram: myfabguy
Old 07-24-2013, 09:15 PM   #33
mooseknuckles
mooseknuckles's Avatar
spend the $300 and buy dropped spindles, cut a coil off the front springs, and make a flip kit for the rear buy welding on new spring perches, or cutting the old ones off and welding them on the bottom of the axle tube....4/6 drop for cheap.
mooseknuckles is offline   Reply With Quote
Old 07-24-2013, 09:16 PM   #34
MWS1994
MWS1994's Avatar
I am not familiar with this part of a vehicle, please explain about the axle saddles. Why do I need them?
I don't know how to weld but my older brother does (I want to learn though).
Old 07-24-2013, 09:22 PM   #35
mooseknuckles
the part on the top of the axle tube where the leaf spring mounts... gets switched to the bottom when doing a "flip".
Old 07-25-2013, 05:56 PM   #36
MWS1994
MWS1994's Avatar
This one looks interesting: http://www.performanceonline.com/196...-c-notch-kits/
Old 07-25-2013, 10:08 PM   #37
Sodell
Sodell's Avatar
You really don't need a c-notch unless you are going below 6"
Scott
Old 07-29-2013, 12:36 AM   #38
MWS1994
MWS1994's Avatar
Since I can't seem to find a flip kit for the C20 3/4 ton, my question now is: Will a C30 1 ton flip kit work? If not, why?
If the C30 kit works, will I need to c notch the frame with this kit or is there enough room under there for 8" drop.
http://www.summitracing.com/parts/ws...view/year/1974
Old 07-29-2013, 01:10 AM   #39
mongoose
mongoose's Avatar
just measure your axle and get a perch for it.. it'll be better and cheaper.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-29-2013, 01:29 AM   #40
MWS1994
MWS1994's Avatar
Can I reuse everything else other than the perches (u-bolts etc..)?
BTW, thanks for the help guys!
Old 07-30-2013, 07:26 PM   #41
Skunksmash
Skunksmash's Avatar
depends on what you classify as poop...
imo most stock trucks ride like poop.. so, a flip kit and cutting a coil would effect the ride a very small mount if at all... especially if you dont put on new shocks or change the wheels/tires and mounts etc.
From what you're saying, it sounds to me like there might actually be a way of doing this, that makes the truck ride BETTER than stock. Is that the case? Is there a method of lowering that can actually improve ride quality? Aside from bagging it, of course.
Skunksmash is offline   Reply With Quote
Old 07-30-2013, 07:46 PM   #42
mooseknuckles
any method will make it ride better....try removing a leaf or two out of the rear leaf springs, that will def help soften the ride.....
Old 07-31-2013, 01:21 PM   #43
tinydb84
tinydb84's Avatar
Dont reuse your U-Bolts. Some people do but its a big safety concern. The plate should be fine. Go to barnes4wd and order the perches and u bolts for your axel.
Good shockes at the right angle and pulling a few leafs will give you the best ride.
David
Instagram: myfabguy
Old 07-31-2013, 01:23 PM   #44
tinydb84
tinydb84's Avatar
On a C20 a flip will net you about 8 inches
Go take a picture of where your axel and springs meet. I doubt the C30 will work. The issue is that the pearches arent flat on the bottom on the 14 bolt rear end. If you have something other than the 14 bolt it may work.
David
Instagram: myfabguy
Old 07-31-2013, 02:17 PM   #45
MWS1994
MWS1994's Avatar
Here's some pics I took.
Old 07-31-2013, 02:31 PM   #46
tinydb84
tinydb84's Avatar
Good ol' bullet proof 14 bolt. Notice the spring perches? They dont make a flip kit for those as they are angled on the bottom side. You will have to do a weld in spring perch. Take a look at the build thread in my signature. I did a shackle and hanger drop and pulled three leafs for a 6inch drop.
David
Instagram: myfabguy
Old 07-31-2013, 02:32 PM   #47
MWS1994
MWS1994's Avatar
Ah, now I see.
I'll take a look at your thread.
Old 07-31-2013, 05:38 PM   #48
Pilofsae
Did mine with 2" drop spindles and 3" springs for front, rear was lowering shackles and flipping the front hanger to raise the height where the front of the leaf spring mounts. then drop shocks and alignment. made dropping the rear relatively cheap compared to the front at least.
Pilofsae is offline   Reply With Quote
Old 08-01-2013, 05:37 PM   #49
MWS1994
MWS1994's Avatar
So here's what I'm thinking. This kit here and I'll take a couple leafs out (how many?). That should drop the rear quite nicely.
Old 08-01-2013, 05:41 PM   #50
Pilofsae
could possibly take out the helper springs. but will still need to get shocks, some kits come with shocks but cost more of course.
