Old 07-26-2013, 10:11 AM   #26
cortcomp
cortcomp's Avatar
Re: Few Stepside to Fleetside bed questions
Here are those support rods from LMC:
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=21
38-7386, 79.95
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-26-2013, 10:21 AM   #27
JWheeler331
JWheeler331's Avatar
38-7386, 79.95
Thanks.
Does anyone have a picture of a complete bed minus the wood? Trying to get a better idea of how the cross sills look because I don't think this one has them all and im not 100% sure how all the bed goes together.
I have been combing through pictures here and the FAQ thread to see if I could see pics but most have the wood or something else covering up what I need to see.
When I look at the LMC catalog.....It shows 6. Well Im not sure if some are just showing two styles or if there should be that many.
JWheeler331 is offline   Reply With Quote
Old 07-26-2013, 10:48 AM   #28
bhc41051
bhc41051's Avatar
http://http://www.4-5-6chevytrucks.com/new-parts.html
Tony at 4-5-6 has the braces you need.
bhc41051 is offline   Reply With Quote
Old 07-26-2013, 11:06 AM   #29
Rich 5150 69
Rich 5150 69's Avatar
Originally Posted by LVPhotos View Post
The 60-62 frame are the same the 63-66 same. The bed mount pads should be the same from step to fleet. The reverse lights were options and are simple to add. Hole for wires I believe and two screws. Not like they shine to see.
This correct to a point, the 60 to 62 frame is wider at the rear, so the very rear bed sill that is attached to the bed has its mounting bosses wider apart by two inches each side, now for the removable bed sills shortbed has four, plus a bed stiffening rail that is attached just behind the wheel wells, plus another note there was a thread a while back concerning frame to sill rubber pads, some original trucks that are on here say they`re trucks don`t have them, not sure either way whether or not they had sill pads.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-26-2013, 12:44 PM   #30
JWheeler331
Anyone know the dimensions on the rubber pads? How thick are they?
Old 07-26-2013, 02:32 PM   #31
Vernski
Mar-K says there's are 1/4" thick, I don't think the thickness is critical as long as they are all the same, but would think no thicker here is there link you might have to hunt for it on the site..Vernski
http://www.mar-k.com/Catalog/catalog.aspx
Vernski is offline   Reply With Quote
Old 07-26-2013, 02:57 PM   #32
JWheeler331
Thanks. I'll check it out.
Old 07-26-2013, 02:59 PM   #33
Vernski
My truck was one of the trucks that had no pads between the frame and cross sills. I could not see any evidence that it had ever been apart in any respect concerning the cross sills. My truck is a 65 GMC and as far as I could see it never had any. But the factory assembly manual indicates they were suppose to be there so I put them in it, anyway I just thought it was better than metal to metal contact. Thanks Rich and good luck JWeeler..Vernski
