Old 07-28-2013, 11:00 PM   #26
lasher78
lasher78's Avatar
Re: weather strip question?
Originally Posted by Vernski View Post
Do you have the sill plates that screw down they hold the seal down?..Vernski
no i will have to try and find some
live like you are dying
lasher78 is offline   Reply With Quote
Old 07-29-2013, 02:08 AM   #27
lasher78
lasher78's Avatar
ok been looking thru threads and found some talking about using late model weather stripping on our 60-66 and the ones i did find all said to use it off of a 87-97 dodge dakota. they claim it works wonderfull, is push-on only took a few min to install, and was dirt cheap ( best reason of all ). they said would only have to trim about 3" off. i am still hoping someone else chimes in on this subject that has used it. i will be looking for one to swipe next visit to junkyard just to try if nothin else...
Old 07-29-2013, 08:51 AM   #28
Jeff La
I know the 2001-2007 chevy trucks have the push on weather stripping and the edge looks the same as the old trucks. It wouldn't be hard to find one and try it, they will be longer.
Jeff La is offline   Reply With Quote
Old 07-29-2013, 02:15 PM   #29
Vernski
I would think these would be available new for replacement don't you think? I wonder and I will check around some Chevy dealers it may be a dealer only item till they get so old..Vernski
Vernski is offline   Reply With Quote
Old 07-29-2013, 03:30 PM   #30
lasher78
lasher78's Avatar
i called local chevy dealership to see about 01 weatherseal but they dont keep anything on hand would have to be special order so you would have to take a look and inspect one at a junkyard or if you happen to know someone that has one of those trucks and is willimg to let you pull theirs off ( like that is going to happen ) lol...
Old 07-29-2013, 09:19 PM   #31
lasher78
lasher78's Avatar
could someone post up a pic of what the rocker wirh lip for seal is supposed to look like before seal is on so i can see how far off mine is and what i might have to do to fix
Old 07-30-2013, 10:24 PM   #32
lasher78
lasher78's Avatar
to top
Old 07-31-2013, 02:36 PM   #33
lasher78
lasher78's Avatar
come on guys, surely someone has a photo of what the rocker is supposed to look like before putting weather seal and sill plate down that they can post. need up close photo so as to see what it looks like to compare to mine.
Old 07-31-2013, 05:57 PM   #34
MisterC
MisterC's Avatar
Post #554 on this page will give you a couple of different angles of what it should look like.
http://67-72chevytrucks.com/vboard/s...336653&page=23
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 07-31-2013, 06:22 PM   #35
lasher78
lasher78's Avatar
thanks MisterC took a look at that but when blow up photo to see up close it blurs out...really needing a up close photo to see lip and channel behide it if there is one ant voth corners and middle..
Old 07-31-2013, 07:23 PM   #36
MisterC
MisterC's Avatar
Look through some of the build threads. The rocker replacement is one of the most common repairs made. I'm sure you'll find a good shot there. Try searching "rocker replacment" and see what that yields for you.
Old 07-31-2013, 10:21 PM   #37
lasher78
lasher78's Avatar
well looked at some photos and best i can tell i am going to have to weld a lip on for tje weatherseal to slip onto. any ideas?
Old 08-01-2013, 03:10 PM   #38
lasher78
lasher78's Avatar
bump
Old 08-01-2013, 04:19 PM   #39
Vernski
What kind of shape is the the floor pan in that area? Maybe you could re-place the the piece or floor pan in the inside rocker that has the lip already on it. They do make re-pops for them..vernski
Old 08-01-2013, 05:27 PM   #40
lasher78
lasher78's Avatar
floors and rockers are all solid so would hate to cut out all good metal just for a lip
Old 08-01-2013, 06:08 PM   #41
Vernski
If it's all good just make one from some scrap metal and spot weld it on where it should go and you've got your lip. It blows me away why someone would remove it in the first place if the floor was solid but then again there's allot of goofy po's out there I guess..Vernski
Old 08-01-2013, 07:16 PM   #42
lasher78
lasher78's Avatar
yeah...makes no sense what so ever
Old 08-01-2013, 10:03 PM   #43
Jeff La
I looked at an 05 cab I have in the back and it has door seals on it, I'll try to get some pics by the weekend.
Old 08-02-2013, 10:51 AM   #44
scottofksu
scottofksu's Avatar
It's actually the "inner rocker" that has the door seal lip on it... Ask me how I know...
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 08-02-2013, 01:25 PM   #45
Vernski
OK Scott what is your story I'm interested..Vernski
Old 08-02-2013, 01:32 PM   #46
scottofksu
scottofksu's Avatar
Oh Vernski, I shouldn't have gotten your hopes up... It's the same old rerun; boy decides to restore truck by himself only to realize that every blessed piece of sheet metal below the doors needs to be replaced... I am now intimately familiar with every curve and crevice in these cabs and their supports and I am still not done!!
Old 08-02-2013, 02:04 PM   #47
Vernski
Unfortunately as you said a common story and been there myself. They call it cognitive insight where you lean through pain. I've seen builds worse and I've seen builds better than mine but it's worth it in the end to say I saved a piece of history. Sometimes there is some humor to be found in our experience and is why I asked. And good luck with your build..Vernski
Old 08-02-2013, 09:38 PM   #48
Vernski
I found this link for Chevy & GMC weather stripping I don't think it's self-stick though..Vernski
http://raybuck.com/c-54796-weatherst...therstrip.html
http://www.ebay.com/bhp/universal-weatherstrip
The ebay link is peel & stick
Old 08-03-2013, 06:15 PM   #49
lasher78
lasher78's Avatar
i contacted that raybuck.com and they emailed me and told me that the weatherseals are the push on kind and they are $25.66 for a kit that does both doors. that aint bad like $12.50 a door. lol
Old 08-03-2013, 08:07 PM   #50
Lugnutz65
Lugnutz65's Avatar
I looked at the link you provided. They don't sell the kit for a 60-63 or 64-66. So what were you planning to buy from them?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
