08-01-2013, 03:01 PM | #26 |
Old member
Re: OverHeat Problems. UnSolved
Depending on if u have AC are not would detirm for me if I ran a clutch are flex. I run AC so I wouldn't use a flex.
Running water additives is just a band aid fix for a problem in the cooling of the motor. Does it work well yes but it didn't fix anything. I have been running a 50-50 mix now for over 20 years in my 71 and it hasn't ever ran hot even in Texas this past June on the power tour. If your motor and cooling system is all good then u shouldn't need any additives in the water. Like I stated find the problem with the system and fix it.
