08-14-2013, 11:38 AM | #26 | |
64-66 CHEVY JUNKIE
Re: Gulfcoast Build Updates (pics)
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
08-14-2013, 11:45 AM | #27 | |
64-66 CHEVY JUNKIE
08-14-2013, 11:50 AM | #28 |
64-66 CHEVY JUNKIE
Posted via Mobile Device. Tackling the wire harness this Morning before it get Hot.. Made me up a transmission and alternater harness..
08-14-2013, 11:52 AM | #29 |
64-66 CHEVY JUNKIE
08-14-2013, 11:54 AM | #30 |
64-66 CHEVY JUNKIE
Posted via Mobile Device.....
08-14-2013, 11:58 AM | #31 |
64-66 CHEVY JUNKIE
Posted via Mobile Device. Still need to drop the pan and wire the 4th gear pres switch..
08-14-2013, 12:00 PM | #32 |
64-66 CHEVY JUNKIE
08-14-2013, 08:30 PM | #33 |
64-66 CHEVY JUNKIE
Posted via Mobile Device. Got the P.S. pump and bracket mounted belt on plus driver side exhaust...
08-14-2013, 08:32 PM | #34 |
64-66 CHEVY JUNKIE
[size=1]Posted via Mobile Device[/size ].
08-14-2013, 09:35 PM | #35 |
64-66 CHEVY JUNKIE
Posted via Mobile Device. Well my China Made Rag-joint Cracked !! Had it on and it spilt, maybe to small I don't know but never had this happen before!! Going bac to Parts House and Getting My Money Bac and go to Maps!!
08-14-2013, 09:36 PM | #36 |
64-66 CHEVY JUNKIE
*Napa
08-16-2013, 02:52 PM | #37 |
64-66 CHEVY JUNKIE
Update, Still didn't get the steering coupling on the gear box, I brought two rag joints from different Auto Stores and each one was way to small one cracked almost in half..
I just picked up a rag joint rebuild kit and when I get bac in town from work I'm goin to pick a part and get a rag joint to rebuild because my original half the splines are grind down smooth from years of Service.. Have Anybody had Problems with incorrect size Rag joints???? Are having them Crack???? Posted via Mobile Device
08-16-2013, 02:53 PM | #38 |
64-66 CHEVY JUNKIE
08-16-2013, 04:24 PM | #39 |
64-66 CHEVY JUNKIE
08-16-2013, 04:34 PM | #40 |
64-66 CHEVY JUNKIE
Also I got the front-clip back on.. It's Starting to look like a truck again
08-16-2013, 04:38 PM | #41 |
64-66 CHEVY JUNKIE
08-16-2013, 04:49 PM | #42 |
64-66 CHEVY JUNKIE
08-16-2013, 09:35 PM | #43 |
looking good
08-16-2013, 10:04 PM | #44 |
64-66 CHEVY JUNKIE
08-17-2013, 12:09 PM | #45 |
64-66 CHEVY JUNKIE
Have anyone else had problems with a steering coupling ??? It's a 72 for a 72 here box??? Thanks
08-18-2013, 12:22 AM | #46 |
60-66 Nut
I don't remember just which one would be correct, but there are 3 different sizes and splines on the steering shaft/couplers. It is possible that the box you have may not really be the year that you think it is. It may have came off of a '72, but someone may have changed it for a different year box sometime in the last 41 years.
08-18-2013, 07:25 PM | #47 |
64-66 CHEVY JUNKIE
That's what I was starting to think Captfab, When I get back home I will pull the gear box and take to auto parts store see if I can have any luck if not then to pick a part and get a good used one...
08-28-2013, 09:04 AM | #48 |
Don't kno if it'll help, but I got a gear box and shaft off of my '85 laying around in my garage. Like I said it might help, just let me kno
Posted via Mobile Device |
08-28-2013, 07:13 PM | #49 |
64-66 CHEVY JUNKIE
Posted via Mobile Device. Thanks Dreamer1, P.M. sent.....
09-04-2013, 04:30 PM | #50 |
64-66 CHEVY JUNKIE
Well I pulled my front clip back off to work on the steering shaft end and coupling rag joint... Since I had the the front off I decided to wet sand and prime also cleaned up the grill....
