08-23-2013, 12:27 AM | #26 |
Re: No spin?
On the top forward section of the drop out.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-23-2013, 04:31 PM | #27 |
Re: No spin?
My numbers on the passanger side top:
JHG 2521 My Numbers next to the load bolt: 393-635 230/ (star wheel symbol) D 2 (is under the symbol)
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-23-2013, 05:19 PM | #28 |
Re: No spin?
I know this is not helping
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-23-2013, 06:07 PM | #29 |
Re: No spin?
Yes, I'd noticed the code is not coming up as a listed code for a 72 or any of the three digit codes I have. Any possibility you can recheck that for us?
08-23-2013, 10:32 PM | #30 |
Re: No spin?
Ok i'll check tomorrow, and even take a pic too.
08-23-2013, 10:33 PM | #31 |
Re: No spin?
Bigdave160, Well thanks for trying, i appreciate it.
08-23-2013, 11:33 PM | #32 |
Re: No spin?
My front axle codes Dana 44:
Casing upper and lower driver side: C-31256 44-5F Tag: No i didn't open it up yet, i will soon and i will count teeth and record numbers. 45:11 4.09 Axle stamp: 7 20 1A4 60332 9 Per service manual, Day Month year/shift/Assy line. I Assume 1=1971, A=first shift, 4=which assembly line The on line service PDF states: If 2 build dates the second is the date the brakes were assembled. I don't think the second set of numbers is a second build date but could be wrong, any feedback?
08-23-2013, 11:52 PM | #33 | |
Re: No spin?
The JHG 2521 was a raised number built into the casting not a steel stamped number if i remember correcly. Am i looking for a stamped number?
08-24-2013, 07:15 PM | #34 |
Re: No spin?
Ok, I was wrong about the raised number part, it was stamped on the top passenger side, overworked and lack of sleep...........
This is what i found by looking again: R JHG 2521 Even with a flash light the sun can play tricks on the eyes when outside, hope i didn't miss even more..
08-25-2013, 09:10 PM | #35 |
Re: No spin?
Hopefully this pic will load.
08-26-2013, 02:39 PM | #36 |
Re: No spin?
One more time.
08-26-2013, 03:02 PM | #37 |
Re: No spin?
what if only the one wheel you are spinning turns? if i spin one of the rear ends i have quick enough i will see the opposite tire spin the same way, but for the most part if i just casually spin the wheel the other doesnt move.
08-26-2013, 03:08 PM | #38 |
Re: No spin?
