Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-02-2013, 12:13 AM   #26
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Parts truck
Curious what you find for 2.5 inch springs. I was looking some this weekend for my 71 K20 and it looks like 2 or 2.5 inch springs are a little over $200 each! Seems high for some leafs, these were tough country and skyjacker i think.
Looking good but if you could just remove the brown areas from the front clip, the truck would look really nice.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-02-2013, 12:30 AM   #27
ryanroo
ryanroo's Avatar
Re: Parts truck
i havent even looked for them. i have a complete 4" set from my green one that i could use but if i can fit my 35s on less i would prefer that. that does seem high for just front springs.
the brown is actually the original paint from that clip. its the dark red color from 67. the entire thing is repainted just so happened that the clip and the truck were both repainted the sameish color. my plans are to dust it in flat black or flat tan at some point. then i will be on the look out for a nice clean body 2wd i can steal the body from
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-02-2013, 07:44 AM   #28
jjzepplin
jjzepplin's Avatar
Re: Parts truck
I have some 4" blocks-bolts=and plates I am not using...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-02-2013, 09:26 PM   #29
ryanroo
ryanroo's Avatar
Re: Parts truck
got home from work today and got a few things done. not visible is the fresh fill of oil in the engine and gear oil in the t-case. visible are the fresh 4 row radiator that is now installed in the modified 67 core support to allow it. i also tossed the battery in it using a cheeeezy hold down from AZ. als decided today to just do a 2.5 inch front spring and 33s
72 K20 12v build
Old 09-02-2013, 09:36 PM   #30
6BT 56
6BT 56's Avatar
Re: Parts truck
I have to tell you ryan I'm really enjoying following this build . Putting all your best of used parts together is making a cool old truck . One that will work better than a new one for years to come . I think you had better blow the budjet and go for some super cup holders ! This the only thing i miss when Im out in my 56 . Ok maby air but thats is what it is . Lookig forward to seeing this movin around . Any plans for a low buck paint job ? I think the fresh 2.5 spring will make the stance just rite . Sticken with the Steel wheels ? Keep up the good work !
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 09-02-2013, 09:39 PM   #31
6BT 56
6BT 56's Avatar
Re: Parts truck
Oops just saw the comment abt the paint above . Sorry for the repeat question
Old 09-02-2013, 09:54 PM   #32
ryanroo
ryanroo's Avatar
Re: Parts truck
Thanks! i find that i am really enjoying this build too. kind of reminds me of high school and college, except now i am choosing to make it cheap but tossing in a few nice parts here an there. in college i pretty much had to do it on the cheap its nice to do something where most of the parts are stock and the engineering is already done. all i have to do is put the right bolt here and connect the right wire there. i really like doing stuff like my green truck build but this is quite enjoyable too.
i was looking at the tunnel yesterday thinking about welding in some cup holders. we'll see about that when i get it on the road.
definitely getting a lot of my misc. used stuff. the radiator i had reconditioned ten years ago for something and never used it. most of the hard parts i had laying around from something. trying to replace all the soft stuff that looks suspect.
going to run the steelies. that was one reason i decided to go with 33s. hard to find a 35 in 16 inch rim. i would really like to run 17s on this truck so it will be able to swap with the green one but i just dont want to drop that cash right now with so much left to spend on the diesel truck. i dont even think i will paint the wheels. call it patina!
Ryan says the hot rod flatz prays pretty easy and it isnt bad on price, so ill probably use that and spray it at work some time when i have the patience for it.
72 K20 12v build
Old 09-05-2013, 03:33 PM   #33
steelhorse
steelhorse's Avatar
Re: Parts truck
Cool build. How about using some wheels from a newer model. I see then on craigslist all the time pretty cheap.
steelhorse is offline   Reply With Quote
Old 09-07-2013, 09:32 PM   #34
ryanroo
ryanroo's Avatar
Re: Parts truck
I like these old crusty ones. they match the ugliness of the rest of the truck.
here it is in some new shoes
they are cooper discovery STT's. didnt really need a mud tire, but i figured it helped continue the theme of redneckery.
i have gotten most of the wiring routed and installed in its proper place. i might go get some new power cables tomorrow or monday and a few glass fuses for the inline fuse holders. i got it rewired for internally regulated Alt. and got the cap and wires on the dist. a few other piddly things. new rear u bolts. finished bending a new rear hard line for the brakes as the one in there was leaking like a sieve.
72 K20 12v build
Old 09-08-2013, 10:23 AM   #35
6BT 56
6BT 56's Avatar
Re: Parts truck
Looks just rite now . Good call on the rubber . those are 33" ? Your not going to paint it flat blk are you ? The old yeller looks rite for the truck . Maby just a scuff and another coat of that ? You will be running soon I guess.
Old 09-08-2013, 11:11 AM   #36
ryanroo
ryanroo's Avatar
Re: Parts truck
they are the metric equivalent of a 33. and for right now, no paint. not sure what i will do when i get there. flat black is definitely on the choices list. its easy and looks decent. i am really considering flat tan though. yellow just isn't my thing. i dont really give a hoot what color it its, but if i am going through the trouble of shooting it, it wont be yellow
72 K20 12v build
Old 09-08-2013, 11:19 AM   #37
6BT 56
6BT 56's Avatar
Re: Parts truck
Flan tan has my vote for sure !
Old 09-08-2013, 08:42 PM   #38
ryanroo
ryanroo's Avatar
Re: Parts truck
Im leaning that way too. itll blend well in the local fauna.
AND.... Drumroll please.
in my best Dr. Frankenstein voice.... IT'S ALIVE!
i drove it around the neighborhood late this afternoon. hits all three forward gears and reverse as it should. seems to function corectly in all other ways as well. i need to poke around and see what is up with the left turn circuit. has hazards and the lights both work but it only blinks like twice and then stops on the turn signal. maybe the flasher itself. or maybe i need to clean some grounds or something. probably need to do some vacuum guage tuning to get timing spot on but so far so good. fires right up on the first bump of the starter with no choke and purrs like a kitten. no leaks of anything unexpected.
Ryan
72 K20 12v build
Old 09-08-2013, 08:53 PM   #39
6BT 56
6BT 56's Avatar
Re: Parts truck
Thats good news . I bet that was fun . There is a truck around the corner that has me looking at your boild and thinking i want to do a fun simple build too. There is a 76 chevy canadian militairy truck . Not as cool as your CUCV's but still neat . They had Dana 44 F 14 bolt rear . 203's th 350's and a 350 4 bbl. They had the cool little things like black out lights , skid plates, tow / lift rings , grill guard , a cool truss on the d44 F as well. the dude has allready pulled the eng and trans , they are in the box . the body seems solid . id like to get it and find a rusty 6.2 truck and transplant it's guts. Add 4 in springs and run my 35 's on it . Just a fun goof around truk for here on the farm . I need sumtin to replace my dodge after it donated it's guts to the 56 .
Old 09-08-2013, 09:03 PM   #40
ryanroo
ryanroo's Avatar
Re: Parts truck
Sounds like fun to me!
72 K20 12v build
Old 09-13-2013, 10:11 PM   #41
ryanroo
ryanroo's Avatar
Re: Parts truck
I have been piddling with stuff, fixing leaks as i can, cleaning out crappy wiring that goes nowhere. etc. been tweaking the timing. it runs pretty darn good now and starts good cold and hot. must be close. maybe ill hook a vac gauge to it this weekend and "set" it. i also ordered a intermediate accumulator oring and spring. some halfwit had pulled the spring before i got into it. it is also leaking out the accumulator cover like a banshee. hope to get that taken care of this weekend as well. maybe next week i can get to the DMV and start to actually go for a little drive here and there. i need to order longer rear shocks and/or move the lower mounts. i havent decided if i need to install the 2 inch steering block or not. i do need to get a boot for one of the tie rod ends. need to wire the elec. choke so it starts and stays running when cold. need to install inner fenders. need to remove more of the aftermarket a/c that was in there.
i ordered some 2 inch springs for the front a while back, and they showed up earlier this week. after work it looked like the rain was going to hold off for a while so i hurried up and installed them. there are 4 mounted tires, an SM465, a radiator, a couple of old D60 rotors and some inner fenders in the rear so it is a little low, but i was still surprised at how tall the front ended up. still looks pretty decent but hopefully it will look better when i chuck all that crap on the trailer.
the springs are tuff country ez-ride.
72 K20 12v build
Old 09-13-2013, 10:12 PM   #42
ryanroo
ryanroo's Avatar
Re: Parts truck
it also seems to be getting a little more fuel that it needs. probaby due to the altitude. it runs great when warm but stumbles if you punch it when its cold. if its just started and you pin it, it will sputter to a stop. stupid carbs...
72 K20 12v build
Old 09-13-2013, 10:52 PM   #43
BigRed76
BigRed76's Avatar
Re: Parts truck
Just read through the whole thread, it's cool to see an ugly duckling getting some attention So in that last pic that's with the 2" front springs installed? It does look a little tall like you said.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-14-2013, 12:36 AM   #44
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Parts truck
I have been going back and forth on what springs I want to run in my Suburban, and the TC 2" were edging their way to the top. I think they just landed solid at #1. That is the height I am after.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 09-14-2013, 02:33 PM   #45
BigRed76
BigRed76's Avatar
Re: Parts truck
I agree, I've been debating between TC 2" & 4" springs for my K20 resto and the 2" springs look like they'd clear 35's
Zach
Old 09-14-2013, 07:25 PM   #46
Vintage Windmills
Vintage 4x4s
Re: Parts truck
Looks good ryan, hows the fit and quality of the springs? Did you find a deal or end up having to pay the going rate of $400+ per pair? I suppose you don't know yet how the truck handles with those on since you mentioned the dmv in the near future...?
Old 09-14-2013, 07:47 PM   #47
ryanroo
ryanroo's Avatar
Re: Parts truck
i bet they would clear 35s.
they fit fine for me. it was a quick swap out in the drive way last night. took maybe an hour and half if that. got them for a bit of a deal. didnt have to pay 400$ but close.
i did drive around the neighborhood a little, but that isnt that great of a testament to how they handle. they seem plenty stiff but that isnt so bad. i also dont have rear shocks on it yet so that gives it a bit of a sway it probably wont have when they are installed
ryan
72 K20 12v build
Old 09-16-2013, 09:06 PM   #48
ryanroo
ryanroo's Avatar
Re: Parts truck
had the camera out earlier. decided another shot of the beater was in order. for being so ugly i'm pretty happy with how this beast looks!
also, i got the accumulator cover leak fixed. drained some oil out of the engine and that slowed the leak there significantly. it also appears as though one of my drivelines will fit in the front. i think i will order a new one for winter, since i am a hubs locked in kind of dude. in the interim, i can make it 4x4 though. i also got the elec. choke hooked up. the abortion of an aftermarket a/c is removed and now i just need to fix and reattach the factory heater wiring.
72 K20 12v build
Old 09-24-2013, 11:51 PM   #49
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Parts truck
Whoa you are an animal! I'm on board for the build...and hope to see you soon.
Old 09-29-2013, 10:48 PM   #50
6BT 56
6BT 56's Avatar
Re: Parts truck
Hi Ryan Whats your thoughts on master cylinders? My 56 still has the 70 K 10 master cylinder under it . With my now dana 60 and 70 combo with much bigger breaks the breaking power is not what it should be also id like less pedal travel. What Master cyl did you use on this truck ?
