Old 08-10-2013, 07:50 PM   #26
70CHEVYBB
70CHEVYBB's Avatar
Re: Disc brake swap brake hose routing? Seems wrong
why not just move the hose to the front of the x member like the way it should be. I did a conversion from drum to disc, I just bolted in new hose mounts in the front and used braided lines. I then bent new steel lines and looks awesome.
70CHEVYBB is offline   Reply With Quote
Old 08-10-2013, 08:20 PM   #27
Superdrag67
Eventually i will do that. I just don't want to keep adding on projects and have this thing sitting in the garage for months and months. I want to drive it! So far its already been much longer than i had planned.
It's fine the way it is now. Hopefully in a few years i can do more of a full body off resto and do things a bit differently.
Superdrag67 is offline   Reply With Quote
Old 08-11-2013, 10:27 PM   #28
eagleuh1
eagleuh1's Avatar
See this ad for a pic. It helped me with mine today. Good luck. Jim
http://jonesboro.craigslist.org/pts/3990843833.html
eagleuh1 is offline   Reply With Quote
Old 08-11-2013, 10:34 PM   #29
mgchevyparts
mgchevyparts's Avatar
Originally Posted by Superdrag67 View Post
Just wanted to update this thread. Won't leave it this way as i dont really care for the way it looks. If i decide to leave it i will make a steel bracket that ties off 2 points instead of one. I think just shorter hoses will work though.
I ended up clocking the hose differently where it goes into the frame which twisted the hose differently. Still wasnt happy with it so i made up the bracket out of some aluminum i had sitting around. It will get me by for the time being.
Mgchevy, do you have a part number for that shorter hose?
If you need a shorter hose tell how long that one measures, end to end and I'll tell you which is a little shorter. Hopefully the repositioning took care of it.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
