Old 08-21-2013, 10:34 AM   #26
obijuan
Re: Tuff country 4" lift. Pinion angles?
Those are brand new springs unweighted. They will settle some and when you put the rest of the truck on it. How much is hard to say.
obijuan is offline   Reply With Quote
Old 08-21-2013, 10:51 AM   #27
argonaut
argonaut's Avatar
it will come down significantly under the weight of the truck body. it looks fine to me.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 08-21-2013, 11:38 AM   #28
Bigdav160
Bigdav160's Avatar
Pinion angles are irrelevant at this stage also
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-21-2013, 01:57 PM   #29
Campbel45
Gotchya thanks again guys
Campbel45 is offline   Reply With Quote
Old 08-21-2013, 10:01 PM   #30
JJH Jimmy
JJH Jimmy's Avatar
Correct me if I am wrong but I don't think the pinion angle will change when weight is added to the frame?
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 08-21-2013, 10:43 PM   #31
argonaut
argonaut's Avatar
As the shackle rotates it changes the angle of the axle. Depending on the at-rest angle of the shackle the angular change of axle will be smaller or greater.
As was previously mentioned, I wouldn't mess with adjustments to pinion angle until you get the truck at final ride height.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-01-2017, 08:18 PM   #32
gmc 2500 4x4
old post, nice info. originally the rear end in my 69 gmc had tapered blocks, i left them out and now its binding, so i jacked up the pinion end 1'' and it dont bind now. guess i better get them back in? it also has a 4'' lift now. any input here?
gmc 2500 4x4 is offline   Reply With Quote
Old 10-05-2017, 08:16 PM   #33
70K10Hunter
70K10Hunter's Avatar
They look short... Did you measure your stock springs? that era trucks had 52 and 56 inch springs. might have been 52 and 54inches
70K10Hunter is offline   Reply With Quote
