#26 |
![]() Join Date: Jun 2002
Re: Project: 1970 yet-to-be-named
Nice work.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#27 |
Keep at it. Progress is progress, even in small bites.
#28 |
Thew in the towel on the lines and picked up a Mastercool flare kit and some AN tube nuts. Wow this thing is awesome. Did a few test flares and had everything done a couple hours later. Can't believe I wasted so much time before I got this tool I should have bought it a long time ago. I used a factory GM fuel filter and reflared some 'fixit' lines to AN to connect to my Walbro pump. Worked great.
Apparently Ace Ventura did the delivery or someone at Mastercool was in a rush packaging it.. Next step, HPTuners! |
#29 |
Went to put plug wires on and 3 on the driver side hit the speed engineering headers. One thing I found from the 01/02 4.8, 5.3 and 6.0 engines that are all at my shop is that the plug wires are not the same length. I don't even know which ones I am using, I think the 01 5.3 wires - but they are about 1 to 1.5 inches longer than the other 2 engines. Either way they don't clear the headers, may have to get some Accell 45degree ceramic units. Or just put factory exhaust manifolds back in to keep costs down.
Poor picture but you can see the culprits here |
#30 |
Everyone who has ever swapped a motor knows how this feels! Now I just have to tie up the 8675309 loose ends and time for a drive!
Oh and build the exhaust.. https://www.dropbox.com/s/6dpes9vq5c...%20PM.mov?dl=0 |
#31 |
accelerator cable... 70's honda civic TB side + '71 c10 firewall side + mountain bike inner cable + hardware store crimp = success! Also apparently in Canada nobody has ever heard of a knarp. Hope I don't have to adjust it! Switched the pedal to 71/72 cable type.
#32 |
Man!! This thing is so clean with the mods, you are killin it with the fabrication for this baby. And hell you couldn't get a cleaner weld on that driveline at any local shop. Indicated in how you did will be just fine
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#33 |
thanks!
a kitchen reno has taken all my time lately but was able to make some progress. got some rubber on the 22's. need to install different studs, I have some m14x1.5 that I'm going to try (same as was the 22's were bolted to) |
#34 |
rears will be a bit different...
#35 |
Kitchen reno finally coming to a close. so after pic1 (turns out tile lathe is sharp....) then pic 2 happened! finally. lq4 has a lot more jam then the tired sbc that was in there. a few things to tie up then time to take it out for a real drive. snow has already hit here and there so not much time left
#36 |
Someone was asking about plug wires on the speed engineering shorty headers. I ended up with Taylor TAY-76046 from summit, they fit well.
#37 |
![]() Join Date: Apr 2005
Kewl project
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#38 |
Lookin good! Looks like that LS went in there pretty nice. I hope I see this thing around town sometime.
My 68 Build http://67-72chevytrucks.com/vboard/s...=1#post7272324 Herb! My C30 build http://67-72chevytrucks.com/vboard/s...80#post7304180 |
#39 |
Finally on the road and hoping to get some miles on before the snow. then take it half apart this winter again for the next phase.
#40 |
#41 |
Cool truck
#42 |
Nothing happened over winter other than some mountain sledding, time to get back at it!
#43 |
Had just decided that an Ididit tilt wasn't happening at this time, gotta keep the costs down, and then happened across a van tilt locally for a great price. Has been sitting in the guys basement for 15-20 years. He thought it was from a 73. Needs some cleanup but feels pretty tight. Anyone know if parts such as pointer/indicator and indicator lens are interchangeable with the truck tilts? Would like to get lens to match up with the 4L60e
#44 |
Another local find. I already bought most of the sensors to get my stock gauges to work with the LQ4 but this will be a heck of a lot simpler and look better to boot!
#45 |
![]() Join Date: Jun 2009
Cool looking truck, love the vintage original feel you left with it
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#46 |
thanks Larry, its slowly getting there!
#47 |
Project: SRS BSNS
Christmas present from my wife. Finally, the project has a name! |
#48 |
Re: Project: SRS BSNS
Well spring is finally here so got the truck out of storage a couple days ago. What better way to start the year by breaking the post ls-swap best of 50 mile trip with a 200mile tow road trip. Serious Business! With the lq4 and bags it pulled amazing. Drivetrain-wise it's head and shoulders better than my 07 f150 was. Just could use more weight and I may have to get some power brakes on it lol. Also note to self, get that brake controller working!!
#49 |
A couple other items ending up following us home
#50 |
Awesome truck! I have the same wheels on mine with flipped center rears. What backspace are you running and how do the wheels fit when aired out? I went with 4" backspace and still have about 1" clearance between the tire and fender. I want to swap out to the wider 70-up rear to get my wheels pushed out a bit more but I'm worried that will be getting too close to the fenders. I already removed the inner well and flattened the lip some, so that helps.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
