08-28-2013, 02:06 AM | #26 |
Re: Parking lamp failures, is LED the fix?
Well I ran the ground from the socket all the way back to the headlight relay ground. That is not to say there may be a problem in the socket itself for the ground. But when I looked at the inside of the socket the hot side contacts are on the bottom and the ground is a tab that flexes over to contact the body of the bulb from the side. Both lights are tied to the same ground but only the passenger side lamp has this issue. I checked voltage at the firewall plug but the parking lamps both get run off of the same line. This weekend I am going to pull the lights again and swap the sides just to check the sockets and go from there I guess. the problem was there before the rewire so nothing has changed in that respect. hhmm
"You can have it Fast, Safe or Cheap. Pick any two" "If you're gonna be dumb, you better be tough" 1965 C10: http://67-72chevytrucks.com/vboard/s...=1#post6114617 1971 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=459552 Last edited by Psycho75; 08-28-2013 at 02:08 AM. Reason: Spelling |
08-28-2013, 05:30 AM | #27 |
That's a damn fine lookin wire loom and I love the socket install....the screws and wire tab are a great idea. Luck with the faulty socket lighting both filiments. Yer 98% there, once done its gonna be factory reliable for the long haul and damn fine looking to boot!
08-28-2013, 06:00 AM | #28 | |
"You can have it Fast, Safe or Cheap. Pick any two" "If you're gonna be dumb, you better be tough" 1965 C10: http://67-72chevytrucks.com/vboard/s...=1#post6114617 1971 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=459552 |
08-31-2013, 02:56 PM | #29 |
Well I worked on the parking lamps during the daylight this time and found that on the questionable socket it wasn't both filaments that were being lit but just the turn filament. It turns out that the socket was wired incorrectly internally. I swapped the connectors and relabled them and its all good now.
08-31-2013, 03:14 PM | #30 |
Very cool. Now ya got reliable lighting and no hood slam worries....Time to do the rear lights! Enjoy yer new visibility. Go ride!
