Old 10-23-2013, 06:43 PM   #26
CTIPTON
Re: Rookie Builder w/68 c-10 stepside std
Frame is back and we have started bolting cross members in place. Will keep things posted as we go.
CTIPTON is offline   Reply With Quote
Old 10-25-2013, 10:13 AM   #27
CTIPTON
Slow progress but progress
Arizona dust on my suspension parts
Old 11-04-2013, 12:02 PM   #28
CTIPTON
Well I have not been doing very good at getting work done on this frame. Some of the issue is wrong parts that I had ordered 2 months ago trying to be ready for when I got the frame back. Oh well just re-order and move forward I guess.
Old 11-04-2013, 12:37 PM   #29
CTIPTON
Newest picture
Old 11-05-2013, 12:59 AM   #30
swamp rat
swamp rat's Avatar
I feel your pain....
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-05-2013, 01:27 AM   #31
Rod Run
Rod Run's Avatar
I have subscribed to this thread
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 11-05-2013, 02:21 PM   #32
1968k10blue
1968k10blue's Avatar
Subscribed, you really are flying through this build aren't you?
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 11-06-2013, 10:24 AM   #33
CTIPTON
A good night last night after a little reaming I got my outer tie rod to fit my drop spindle. Got ALL my steering linkage in and rotors, calipers and rubber brake hoses installed. Rear differential is next. pix of progress
Old 11-06-2013, 10:25 AM   #34
CTIPTON
This is what I was building and racing before I started this truck build
Old 11-06-2013, 11:28 PM   #35
swamp rat
swamp rat's Avatar
Looks like a blast!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-07-2013, 09:31 AM   #36
CTIPTON
Last night I cleaned the rear differential and pulled all seals as well as the axle bearings and primered the housing. That Easy Off oven cleaner really does cut down on the amount of grease cleaning time,this thing was very thick with old grease and dirt.The ring and pinion(3.73 ratio) looks to be in really good shape so I think I am going use them, later I will install the posi carrier. I didn't snap any before pix, these are just after the Easy Off cleaning.
Old 11-07-2013, 12:50 PM   #37
Rod Run
Rod Run's Avatar
Wow that EasyOff works great huh?
Old 11-12-2013, 07:27 PM   #38
CTIPTON
NEED SOME HELP PLEASE????? I just bought two front rubber brake hoses for a 1972 Chevy C-10. The left side hose fits like it should. The right side fits the caliper properly BUT!!!! the other side has a Larger fitting on it to accept a larger brake line fitting. Is this normal and I need to put a larger fitting on my brake line or is it the wrong brake hose??? Remember my truck is a 1968 that HAD drum brakes(converted to disc for a 72) on the front and I am using the original right side steel line(small fitting on both ends). I have ordered the same brake hose from 2 different companies and they both have the larger fitting. Can someone help?????
Old 11-12-2013, 07:28 PM   #39
CTIPTON
That last rear diff. picture is after primer.SORRY
Old 11-12-2013, 07:57 PM   #40
swamp rat
swamp rat's Avatar
It sounds like you have the wrong hose for that side, just tell whom ever you got it from what the problem is and tell them the other side was the correct fitting size. I believe the 67-72's are 7/16 inverted flair fittings and the newer trucks are 5/16 inverted flair. I would believe someone put the wrong hose in the right box. EDIT: take them both back so you can show them the correct fitting size.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-18-2013, 03:49 PM   #41
CTIPTON
A little more progress. Chassis is up and rolling,brake lines run and fuel tank is in and lines for it ran also. On my brake hose---I just cut the line slid a larger fitting on, flared the line and hooked it up. I am ready to build my engine and drop it in next, then fit the cab on its new mounts.
Old 12-04-2013, 09:59 AM   #42
CTIPTON
Built a nice strong sbc, 700R4 trans with a dress up kit. It acually looks good sitting in the frame. Having a little trouble finding a direct bolt on SHORTY header. I tried the Chevelle header and it didn't fit so was thinking about the block hugger header. Would like some feedback on those, if i could get some. Next I am going to fit the cab and do a mock up. A/C is ready to get mounted. New steering column is ready to mount. Would really like to get some header info. THX guys for your help.
Old 12-04-2013, 03:26 PM   #43
swamp rat
swamp rat's Avatar
Somebody on this forum was selling a set about a month ago. I would try the search button and type sbc short headder and see if it comes up
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-04-2013, 05:14 PM   #44
mcbassin
Still Learning
mcbassin's Avatar
Very nice build. Looks like you're off to a great start.
mcbassin is offline   Reply With Quote
Old 12-04-2013, 05:27 PM   #45
72bowtiestepper
Block hugger headers will work if you mount the engine in the 6 cyl. (rear holes in the frame) position. If you are going to run a HEI ignition, the fit will be tight...but will work. Hope this helps your header situation.
72bowtiestepper is offline   Reply With Quote
Old 12-04-2013, 05:44 PM   #46
CTIPTON
Thanks guys. I also found out that there is an aftermarket engine stand and mounts that opens up the header possibilities. Will let you know how that goes.
Old 12-04-2013, 07:13 PM   #47
mx289
mx289's Avatar
Early classic sells a set of headers for 67-72 trucks.Great company.
mx289 is offline   Reply With Quote
Old 12-04-2013, 08:35 PM   #48
CTIPTON
Those are the headers that I have. The problem is the stock engine stands are too high and the header hits. I now have the CPP engine stands so I will mount them and let you know if they are the cure.
Old 12-04-2013, 11:58 PM   #49
CTIPTON
Well back to the drawing board---those engine stands made no difference. I will take another look at those headers from E.C.E. to see if they are the exact same as the headers I have(was told they where the same). Thx again for your help.
Old 12-05-2013, 12:33 AM   #50
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Your build is looking great the frame and engine is really nice.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
