#26 |
![]() Join Date: Jul 2013
Re: 85 el camino w/ tpi
Yeh it has been changed to a MAP setup now. I am going to check to see it to the computer and if its all intact. If the diaphragm is only thing bad it still takes a different one than a stock fpr or no? Finding it is a bit of a pain especially since I don't know the brand, or maybe all aftermarket are the same size
1967 chevy c-10 stepside shortbed 1985 el camino w/ tune port injection |
#27 |
Do you have a check engine light hooked up? You can pull codes from an OBD1 computer quite easily by jumping the A and B terminals in the ALDL.
Check out http://chevythunder.com/ , its the go to resource on the internet for TPI swaps and troubleshooting. |
#28 |
The aftermarket fpr uses a stock diaphragm. The only difference between a stock fpr and aftermarket is the adjustment provision.
#29 |
See I was wondering if that was the case also I had assumed it was but not sure with the diaphragm
