09-13-2013, 11:40 PM | #26 |
Re: Project '33
some more
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
09-13-2013, 11:42 PM | #27 |
Re: Project '33
finished bracket, ready to install
09-14-2013, 02:01 AM | #28 |
Re: Project '33
Slick...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-16-2013, 12:01 PM | #29 |
Re: Project '33
Thanks Jim, can't wait to start my thread on the 49 too. Camaro stub, homebuilt radius arm independent rear susp, 55 Chevy truck dash (wraps into doors), LS1, etc. I'm in WAY over my head! Hoping to have this one done for Truck Nats next year.
09-16-2013, 07:20 PM | #30 |
Re: Project '33
Chris, 49 sounds like a sweetheart, can't wait till you get started. I've seen you work up close, I don't think your over your head..Jim
09-16-2013, 10:11 PM | #31 |
Re: Project '33
Looking Good! Subscribing to see this one some together.
Chad
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans Project Dooley One-Ton 4x4 on 38.5s Corn-binder build |
09-16-2013, 11:07 PM | #32 |
Re: Project '33
Thanks Jim, I've already started, just not enough for a build thread yet. Thanks Chad, I Hope it comes out nicely.
11-13-2013, 07:44 PM | #33 |
Re: Project '33
Definitely a cool build. Looking forward to the results. Subscribed!!
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
11-13-2013, 11:08 PM | #34 |
Re: Project '33
Thanks Blue Bomber. it has been slowly progressing. Chris doesn't have as much time as I do, and wants to be there helping with the work. It drove under it's own power for the first time since 1971 last Saturday!
11-14-2013, 12:26 AM | #35 |
Re: Project '33
Hey Chris, progress is progress, catch you later...Jim
11-14-2013, 11:27 AM | #36 |
Re: Project '33
Thanks Jim... been working on my 49 LS1 project lately. Hoping to have it done in time for All Truck Nats 2014... I'll start a thread when I get a little farther.
11-14-2013, 04:13 PM | #37 |
Re: Project '33
Ahem, (thread for '49), Ahem
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-14-2013, 08:15 PM | #38 |
Re: Project '33
Make sure to post it on one of your existing threads so I don't miss it...Jim
11-14-2013, 11:01 PM | #39 |
Re: Project '33
Alright Elco.... the 49's got a LONG ways to go, but I'll work up a thread for what I've done so far. Check for it in my signature.
11-24-2013, 12:36 AM | #40 |
Re: Project '33
Got a little work done on the '33 today... Chris decided he wants to mix new wood with some steel to give it a little more structural support. 1st pic is of the dry-rotted stock wood along the back of the cab. 2nd is the new 1x2 1/8" wall square tube structure we built. Much more solid!
11-24-2013, 11:41 AM | #41 |
Re: Project '33
Here's pics of the finished (and fully functional) pedal assembly. The frame bracket is a highly modified '53 chevy piece. The actual pedals are original to the '33.
11-24-2013, 05:21 PM | #42 |
Re: Project '33
Chris, looks great...Jim
11-24-2013, 09:18 PM | #43 |
Re: Project '33
Thanks Jim,
Not too much done today. just some little things. built a new batt. box, and replaced the back wall of the bed. The old one was a tad rusty. The new one is a 1950 Chevy piece that we narrowed 4". The tailgate is from a '37 Chevy (Jim Carters repro, but 2nds). Fit the 4" narrowed box perfectly! And, I love the cursive Chevrolet script!
11-25-2013, 12:19 AM | #44 |
Re: Project '33
Looking good Chris...Jim
12-21-2013, 12:23 AM | #45 |
Re: Project '33
Small update on this one.
Chris decided against the drop axle, and we're gonna just pull some leaves out of the front spring pack. Going down to 18" tires, it ought to give us about 4 inches of drop. Not quite the 8" I would have liked to see, but it's not my truck. Spend the last several days wrestling with kingpins. Here's the 53 Chevy 3/4 ton axle we intend to put under the truck. New kingpins, brakes, hardware, etc. We rebuilt the wheel cylinders also, So it will stop with fluid instead of friction. He also picked up some 80's dodge dually front adaptors, so we can keep the cool wheels. Hoping to get this axle under the truck this weekend.
12-22-2013, 12:21 AM | #46 |
Re: Project '33
Here's some updates for this project. I saved the batt box opening from my 49 project to integrate into the 33's floor. We also got the front axle almost finished up (need some shorter U-bolts). Wound up pulling 5 leaves out of the front spring packs. Should be a total drop of around 4-4.5" once we account for the vehicle weight on the springs. Here's the pics.
12-22-2013, 12:26 AM | #47 |
Re: Project '33
Here's the last few. I think the wider spacers look great, and I can't wait to see it on the ground tomorrow!
12-22-2013, 01:29 AM | #48 |
Re: Project '33
Looks good Chris...Jim
12-22-2013, 09:14 PM | #49 |
Re: Project '33
Thanks Jim. Got some more done today. truck is on the ground with the new axle under it. Wound up losing about 5.5" of ride height with the new setup.
I think it looks kinda butch with the new stance in the nose. We also put the freshly cleaned tank in and ran the fuel line, so no more nurse tank required. Next time we get it in the shop we'll pull a bunch of springs out of the rear packs to drop them down as well.
12-23-2013, 12:18 AM | #50 |
Re: Project '33
Big difference and looks good...Jim
