Old 08-31-2013, 11:41 AM   #26
79Betty
79Betty's Avatar
Re: Post your cruising rpms @60mph
79
350 quadrajet
All stock
4.10's
35x12.50's
10 city 13 highway @ 2500 rpm
Would get better if i'd keep my foot out of it lol
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 08-31-2013, 12:15 PM   #27
Skunksmash
Skunksmash's Avatar
Originally Posted by Blackpony View Post
Hehe
Ehhh I probably have around 4k in it. My biggest expense though was I bought the parts little by little as I had the cash and found a deal. I completely rebuilt my engine, new pistons, rods, crank, cam, springs etc. it was a new engine when I installed it. Also I bought a fully built trans and new converter. If you go 5.3 take out and can get say an engine and trans with the accessories and wiring, you should easily come under 2k total. I was just picky and wanted the aluminum 5.7 rather then an iron block so they tend to me a bit more expensive.
Yeah I could get an all aluminum 5.3, but the difference in weight is only 40lbs. Still might do it, don't know. Putting spark plugs in aluminum heads may not be stress that I want in my life. Unless they got smart and started making that part iron. Then again, maybe the iron blocks still have aluminum heads...
Skunksmash is offline   Reply With Quote
Old 08-31-2013, 08:49 PM   #28
Blackpony
Blackpony's Avatar
They actually make an all iron ls engine. cant remember the year but it is a 6.0 and usually they are in 2500 hd trucks. There should be no reason to change plugs but maybe every 2-3 years unless you drive a bunch. 50k on a set of plugs is normal life. There is 0 difference in putting plugs in an aluminum head over an iron head. Our shop car gets new plugs every 2-3 passes down the track. With 1300 hp you have to keep fresh plugs in so you dont burn up the engine. we are yet to have an issue. Also the aluminum block is around 65-70 lbs lighter then its iron counter part.
Blackpony is offline   Reply With Quote
Old 08-31-2013, 09:33 PM   #29
eray92
eray92's Avatar
I'll porbably sell the 4.56 gears to some pretty cheap and try to trade my 20s for some 15 wire wheels that will raise my rpms up a bit
eray92 is offline   Reply With Quote
Old 09-01-2013, 12:04 AM   #30
Gregs71
87 st cab long bed 4x4
350tbi /th400 / 4.11 grears at 55mph= 2400rpm= 8mpg
89 crew/dually 4x4
454tbi / th400 / 4.11 gears at 55mph=2400rpm=8mpg
Need to add an OD!!
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 09-06-2013, 06:50 AM   #31
wraprail
wraprail's Avatar
85 C10
Stock 305 Headers
T56 .50 6th
29" tire
3:70 r&p
1600@80mph
No idea at 60mph, who drives that slow?
wraprail is offline   Reply With Quote
Old 09-06-2013, 06:57 AM   #32
eray92
eray92's Avatar
Originally Posted by wraprail View Post
85 C10
Stock 305 Headers
T56 .50 6th
29" tire
3:70 r&p
1600@80mph
1326@60
Old 09-07-2013, 09:26 AM   #33
makman1297
makman1297's Avatar
77 K10
350 TBI 700R4 NP 208
StarFire 285/75R16
4.10 Gear Ratio
1750 & 60 MPH
Gets 16 MPG on long cruise.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 09-07-2013, 10:00 AM   #34
Corts60
Just here to tinker
Corts60's Avatar
'78 short box 2wd lowered
350 Diesel,t400,GV o/d-.78 final drive, 3.40 in the rear. With a 27" tire I was at 2300 RPM at 70 MPH and if I drove all highway I got 23 MPG. 18 MPG in the city
I just swapped in 3:73's with limited slip in the rear which should put me around 2500 RPM at 70. We'll see what I get this next week for fuel mileage.
Old 09-07-2013, 10:21 AM   #35
Rubble
Originally Posted by Keith Seymore View Post
Tell him about the MOPAR A833 manual overdrive trans that you could get in these trucks....
http://www.customclassictrucks.com/t..._transmission/
K
I have the same tranny in my 82 K25, 6.2/833/208/3.73.. It's howling a bit in OD,but it still gets 20mpg on highway in 3rd at 60 mph. Not bad for a 6" lift on 35s . 22-2300 @ 60. I like this tranny better than the 465, lot shorter throws too..
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 09-07-2013, 10:27 AM   #36
Rubble
86 K20 350/465/208/4.10s 7" lift on 35s runs about 2500 rpm @60 about12-14 mpg
81 K35 CCLB 454/400/205/4.56 rpm unknown,6-8 mpg.
86 K25 6.2/400/208/3.73s 4" lift on 33s runs about 2600 @60 about 16-18 mpg.
Old 09-08-2013, 09:15 PM   #37
slugish
Slugish
Originally Posted by INSIDIOUS '86 View Post
26.5 tires and 3:73 gears and th350. 3000rpm at 60mph 3500 at 70mph which is where I cruise at haha. I need a nice 200r4
Yea, I had 373 gears & a 350 3 sppeed at one time , & youre right on at 3000 rpms at 60 mph . Too steep for me , put in a 3.08 ,didnt like the performance , ended up with A 342 (BOUT 2500-2600 RANGE AT 60) Still not great over 70 , but I got tired of throwjng money at ring & pinions , plus the labor of someone else doing the work. Oh well you live & learn . I did a lot of things to my truck before I GOT ON THIS FORUM . yOU ARE SMART IF YOU GET ADVICE ON THIS FORUM, LIKE A LOT OF YOU ARE DOING, BEFORE YOU MAKE YOUR MODIFICATIONS
slugish is offline   Reply With Quote
Old 09-18-2013, 08:12 AM   #38
Keith Seymore
Keith Seymore's Avatar
Sorry to be joining so late, but I've been away on business and haven't been driving the truck.
Looks like about 1900 rpm; 4.3L V6, MY6 manual overdrive trans (.73 ratio), 3.73 rear axle, P235/75R15 tires.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 09-18-2013, 08:57 AM   #39
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
ZZ4 355 HP!!!
700R4 custom built
3.08 gears
255/60R15
1950 RPMS @ 70 MPH
18.5 MPG :METAL:
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
