01-14-2014, 01:22 PM | #26 |
It's Better With Nitro
Re: What penetrant do you use on rusty bolts?
If there's a lot of rust/corrosion, I use Kroil. It can leave a strong odor. Otherwise, I use Gibbs Brand on just about everything else (drag cars, hot rods, etc.), including using it as my primary CLP on my guns - its the only CLP I use on my M4s and shotguns.
01-16-2014, 02:44 AM | #27 |
hmmm... WD40?
01-16-2014, 11:42 AM | #28 |
Better as a water displacing ("WD") oil than a penetrating oil.
01-18-2014, 02:37 PM | #29 |
i use pb, if its real stubborn i will hit it with some heat
"DON'T TOUCH THE TRIM!!"-Early Kyler |
01-19-2014, 10:35 AM | #30 |
i use Tool Box Buddy by Lucas oil
1950 Chevy 3100 |
03-03-2014, 03:12 AM | #31 |
Kroil
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
03-03-2014, 03:36 AM | #32 |
http://67-72chevytrucks.com/vboard/s...d.php?t=617960 recently did a similar thread.
04-10-2014, 08:55 PM | #33 |
I guess I'm cheap. Heat up then stick it with a candle. Let the wax penetrate then off she comes!
04-13-2014, 02:49 PM | #34 |
PBlaster. Have a VW bug in the shop now that has been sitting outside since 1986. All the brake lines and bleeders came loose no problems!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
04-21-2014, 12:09 AM | #35 |
Kroil Just don't get it on yourself works awesome.... Damn Cat loves the stuff I cant get rid of the little bugger when i spray it lol.
04-25-2014, 12:38 AM | #36 |
ZEP 45. I used to sell the stuff and it works pretty well. Twister (also by ZEP) is another good one.
06-13-2014, 12:13 AM | #37 |
aerokroil all the way! The local Napa stores carry it around here. I keep 2 cans in my tool box all the time
06-13-2014, 12:34 AM | #38 |
The "Unsung Hero" of the penetrating oil world
06-28-2014, 05:34 AM | #39 |
Ivs always been a fan of LPS. U can get it at grainger...but ive been turned on to liquid wrench "penetrating oil" stuff works damn good...courtesy of my job...
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
07-16-2014, 02:16 PM | #40 |
Schaeffer "Penetro 90"
07-16-2014, 03:47 PM | #41 |
07-16-2014, 06:35 PM | #42 |
PB Blaster works and cheap compared to some others
07-16-2014, 08:22 PM | #43 |
Funny you should ask, today I started a resto on a 71 Long Box for a long time customer. Trying to take apart the bed I found all bolts were rusted well. I used PBlaster on them and I can now say they all came out. So I must say PB is the bomb.
07-16-2014, 09:31 PM | #44 |
07-17-2014, 10:23 AM | #45 |
X2…I've used Gibbs Brand since the '80s for my racing and fabrication, and it's the only CLP I use on my rifles. It works on about 80% of the rusty fasteners. The other 20% I use Kroil from Kano Labs.
08-07-2014, 09:45 PM | #46 |
78K & 79C Jimmys
liquid wrench or PB works for me
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-09-2014, 04:00 AM | #47 |
+1 for PB Blaster.
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=564420 |
10-11-2014, 01:45 AM | #48 |
10-11-2014, 03:19 PM | #49 |
If you do a search, someone posted an actual test of a bunch of different penetrants with the torque required to break loose rusty bolts/nuts. The clear winner was acetone/ATF. I didn't really believe it, until I mixed some up. It really does work well. It's not as convenient as the spray cans, but I keep some in a plastic spray bottle. Make sure you shake it up before you use it.
10-11-2014, 07:33 PM | #50 |
