09-08-2013, 03:17 PM | #26 |
Re: 2002 5.3 need help troubleshooting
Where is everyone? Out wrenching? I know everyone is back home from church.
I have my fingers crossed the soaked injector will solve my problem.. Posted via Mobile Device
09-08-2013, 03:30 PM | #27 |
Testing my patience. I am dying to plug the injectors back in, but I think I will hold out for tomorrow.. Don't want to have to do it twice
09-08-2013, 04:16 PM | #28 |
meowMEOWmeowMEOW
2 hours of waiting is testing your patience.
We were out in our working trucks enjoying the last weekends of summer....if you want me to rub it in. Don't put cleaner on the electric plug. Its not to say that it would really cause damage, i just don't like exposing electronics to much besides contact cleaner and dielectric grease. With at least the end in solution, your getting some cleaning effect. If you can submerge the body a bit so the solution get "in" there a bit better, thats fine too, just keep the little electrical part up out of the solution. If you lay the injectors on their side in a shallow tupperware, you should be able to keep the plugs "up" while the rest of the body sits under the solution. I mention in another thread as well, there are instruction on google/youtube for how to mod a simple 12v source to trigger the injectors while they are in cleaner.
09-08-2013, 10:19 PM | #29 |
Ok, it IS ALIVE.
I HAVE 1 o-ring on #4 lifter that is leaking. There is a skip, am thinking there are a couple of injectors that still need some attention. My major concern is i have a water leak coming off the pass rear of the engine. I first thought it might be the vent tube which runs from side to side, but ran my hand in that area, I didn't feel water there. I have seen no freeze plugs in these engines so I don't think that is a possibility. I know there is a threaded insert just above the starter. With the starter in place I am unable to eliminate this as a possible source. Appears to be coming from somewhere in the starter region. Do you guys have any suggestions? Posted via Mobile Device
09-09-2013, 10:09 PM | #30 |
I was wrong the liquid was gas and not water........
09-09-2013, 10:17 PM | #31 |
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
09-09-2013, 10:21 PM | #32 |
This is what I plan to put the 5.3 into
09-09-2013, 10:24 PM | #33 |
Lol, I couldn't resist
09-09-2013, 10:33 PM | #34 |
Got that fuel leak fixed, right? Looks like a nice truck.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
09-10-2013, 12:28 AM | #35 |
Like I said fuel injector boring kits are only like 5 or 6 dollars anyte I pull any injected they get new orings
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-10-2013, 12:52 AM | #36 |
meowMEOWmeowMEOW
if your getting fuel on the back of the engine and the o-rings have been handled, make sure that the push on connections on the fuel rail are sealing.
09-10-2013, 10:20 AM | #37 |
looks like it is time to pull the fuel rail again... and fight the clips...
i am thinking i will do this after the engine is pulled..... the clips will be much easier then.
09-10-2013, 03:15 PM | #38 |
the fuel supply lines(at quick disconnect) appear to be sealing.... i have to wonder if those fuel lines may have been compromised between the engine and the firewall, during the wreck....
09-13-2013, 08:57 AM | #39 |
David, i pulled the fuel rail completely off last nite.... am picking up some new o rings to day @ NAPA. going to stab it back on tonite..... hoping for no leaks so i can move on..
thanks guys
09-13-2013, 09:50 AM | #40 |
Be sure to lube the orings on the injectors so they don't get damaged when puttting them back in. Just throwing that out ther in case you didn't know.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
09-13-2013, 10:12 AM | #41 |
good info... thanks
09-13-2013, 11:05 AM | #42 |
Chev3600 thanks
09-13-2013, 10:14 PM | #43 |
Ok guys, just finished verifying all the injectors work/spray. All seem to be working fine.
The trusty syringe, battery, rubber hose with clamps and PB Blaster did the trick. In the videos, the guy used a fuse, but I went straight to the battery. Cleaned everything, installed the new o-rings, inserted injectors back into the fuel rail..(yes, I lubed them,don't want damage them this time around).installed the retainer clips......boy the clips were much easier to install on the table. Good stopping place, will finish in the AM. Posted via Mobile Device
09-14-2013, 12:45 PM | #44 |
09-14-2013, 12:46 PM | #45 |
Trying to post vid.. Not working
09-14-2013, 12:47 PM | #46 |
Put it all back together. Runs like a champ. Happy camper.
Thanks guys for all your help Posted via Mobile Device
09-14-2013, 11:38 PM | #47 |
Location: Sunny, Florida, some might call it South Alabama
You have to post the vid to YouTube and then link it to here pap
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
09-14-2013, 11:48 PM | #48 |
Ok bud, maybe I'll try that tomorrow. I drove it down the road. Couldn't tell much about the tranny. Ruff ride
09-15-2013, 06:41 AM | #49 |
I bet it was, those wheels/tires have seen better days...lol...you might try lifting the rear end and blocking the front tires and seeing if it goes through all the gears.
